The other......
The other......
.......Eastenders Capri http://www.carandclassic.co.uk/car/C817145
Re: The other......
Happy Birthday (44)????Andrew 2.8i wrote:Hi Andy,
Good spot. Of the two, I definitely prefer Mike's old one.
But this is the rare 4 speed Will be interesting to see what it sells for.
From August 2008 @ 28263 miles to Oct 2009 @ 58795 (30500 miles) Speedo change And prob 128263 miles in 2008
MOT history;
Registration number: NOJ234X
Vehicle make FORD Vehicle model CAPRI Date first used 5 March 1982 Fuel type Petrol Colour Black
Test date 7 November 2016 Expiry date 6 November 2017 Test Result Pass Odometer reading 59,264 miles MOT test number 3425 2696 4483
Test date 30 September 2015 Expiry date 12 October 2016 Test Result Pass Odometer reading 59,176 miles MOT test number 1976 1627 4199 Advisory notice item(s)
nearside front upper Macpherson strut has slight movement in the upper support bearing assembly (2.5.B.1b)
under body sealant
Test date 7 October 2014 Expiry date 12 October 2015 Test Result Pass Odometer reading 59,140 miles MOT test number 4677 9038 4202 Advisory notice item(s)
Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Nearside Front wheel bearing has slight play (2.5.A.3c)
Offside Front wheel bearing has slight play (2.5.A.3c)
Oil leak
Test date 7 October 2014 Test Result Fail Odometer reading 59,140 miles MOT test number 4361 0048 4239 Reason(s) for failure
Offside Front Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Oil leak
Test date 9 October 2013 Expiry date 12 October 2014 Test Result Pass Odometer reading 59,059 miles MOT test number 6291 6228 3283 Advisory notice item(s)
Nearside Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
diff has slight oil leak
all tyres cracked on sidewalls
engine oil leak
slight exhaust leak from o/s rear box joint
Test date 9 October 2013 Test Result Fail MOT test number 3051 3268 3414 Reason(s) for failure
Nearside Steering rack gaiter split (2.2.D.2d)
Offside Steering rack gaiter insecure (2.2.D.2d)
engine oil leak
Test date 2 October 2012 Expiry date 12 October 2013 Test Result Pass Odometer reading 59,006 miles MOT test number 3579 5607 2233
Test date 3 October 2011 Expiry date 12 October 2012 Test Result Pass Odometer reading 58,979 miles MOT test number 1879 1637 1281 Advisory notice item(s)
Nearside Steering rack gaiter deteriorated (2.2.D.2d)
Test date 4 October 2010 Expiry date 12 October 2011 Test Result Pass Odometer reading 58,935 miles MOT test number 8244 7777 0293
Test date 4 October 2010 Test Result Fail Odometer reading 58,934 miles MOT test number 3740 5717 0242 Reason(s) for failure
Nearside Rear wheel bearing rough when rotated (2.6.1)
bonett catch stiff
Test date 13 October 2009 Expiry date 12 October 2010 Test Result Pass Odometer reading 58,800 miles MOT test number 2342 5658 9217
Test date 1 October 2009 Test Result Fail Odometer reading 58,795 miles MOT test number 7911 8447 9288 Reason(s) for failure
Brakes imbalanced across an axle (3.7.B.5b)
Offside Outer Rear Road wheel with a slightly distorted bead rim (4.2.A.1a)
Nearside and offside front wiper blades not effective
Oil leak
Test date 22 August 2008 Expiry date 21 August 2009 Test Result Pass Odometer reading 28,263 miles MOT test number 3647 0503 8240 Advisory notice item(s)
Nearside Outer Front Road wheel with a slightly distorted bead rim (4.2.A.1a)
Test date 3 August 2007 Expiry date 9 August 2008 Test Result Pass Odometer reading 27,317 miles MOT test number 2019 1551 7289
Test date 3 August 2007 Test Result Fail Odometer reading 27,317 miles MOT test number 8825 6561 7277 Reason(s) for failure
Exhaust emissions carbon monoxide content excessive (7.3.B.1a)
Exhaust has a minor leak of exhaust gases (7.1.2)
Test date 10 August 2006 Expiry date 9 August 2007 Test Result Pass Odometer reading 25,574 miles MOT test number 3303 7202 6446
Re: The other......
Thanks Andy,andyd wrote:Happy Birthday (44)????
No, I haven't wound the mileage back...........
Not long to wait for the auction (December 8th). Will the TV history of this car significantly affect the sale price?
Judging by the MOT history, Alfie Moon must have spent more time under the arches in Phil's garage repairing his Capri than he spent in the Vic!
Re: The other......
We all know some MOT Testers are stricter than others, so some advisories may never have been done or needed.....Andrew 2.8i wrote:Thanks Andy,andyd wrote:Happy Birthday (44)????
The estimate seems about right, but they are rare so could be more!? Definite head over heart on this one.
Andy
Re: The other......
Happy Birthday AndrewAndrew 2.8i wrote:Thanks Andy,andyd wrote:Happy Birthday (44)????
It'll be good to see what price it goes for, it's a nice looking Capri anyway, interesting to see whether bidders value it's TV appearance over the car itself.
Re: The other......
Not sold, along with some other Capri's......
Full List http://www.brightwells.com/classic-moto ... mber-2016/
Re: The other......
Hi Andy,andyd wrote:Not sold, along with some other Capri's......
Not one of the V6 Capris sold. Are they falling out of favour with the buyers, or have the reserves been set too high?
Re: The other......
Maybe both.....A mate has been to a couple of auctions recently, and one White 2.8 Capri especially was poor although it had been resprayed.Andrew 2.8i wrote:Hi Andy,andyd wrote:Not sold, along with some other Capri's......
Sills still had signs of rust when you opened doors
Seems you cant take the vendors word at auction
- Car(s): Concourse MK1 3.0E - great MK2 3.0S - MK1 Granada (Consul GT), MK2 Jag, RSTurbo Escort, MG Midget and STILL looking for a MK3 3.0S
Re: The other......
Hi guysandyd wrote:Maybe both.....A mate has been to a couple of auctions recently, and one White 2.8 Capri especially was poor although it had been resprayed.Andrew 2.8i wrote:Hi Andy,andyd wrote:Not sold, along with some other Capri's......
Been a while and hope all is well - I didn't see the cars in person but was interesting to see most of the fords didn't sell - could be many things like reserves as you mentioned or condition or just the fact that Brightwells aren't an easy place to get to and don't seem to deliver the best prices at auction for the seller. Going from history, it looks like Silverstone auctions are the way to go (for the seller) for rare / outstanding condition Fords as they regularly set record sale prices - lesson maybe if you are looking to buy at auction, then Silverstone isn't the place to go but for the seller its great news
