3.0 Ghia
Re: 3.0 Ghia
Hi Paul,
Don't know the car but it looks great, and in one of if not the best Capri colours imo Shame it's an Auto
Nice to see it's not gone on
Andy
Andy
Re: 3.0 Ghia
Hi Paul,
Sorry, I don't know this car either, but as Andy says, it looks very tidy indeed.
Not a bad price for such an original car.
- Car(s): Concourse MK1 3.0E - great MK2 3.0S - MK1 Granada (Consul GT), MK2 Jag, RSTurbo Escort, MG Midget and STILL looking for a MK3 3.0S
Re: 3.0 Ghia
Think you're right Andy - one of my favourite colours too - I know what you mean about auto though being a Ghia model think it works quite well - wonder what the mileage is -andyd wrote:Hi Paul,
Andy
Re: 3.0 Ghia
Hi Andrew - good price if the pics and write up are anything to go byAndrew 2.8i wrote:Hi Paul,
Re: 3.0 Ghia
MOT history and mileage;paulda wrote:Think you're right Andy - one of my favourite colours too - I know what you mean about auto though being a Ghia model think it works quite well - wonder what the mileage is -andyd wrote:Hi Paul,
Andy
Registration number: EWS989W
Vehicle make FORD Vehicle model CAPRI Date first used 13 April 1981 Fuel type Petrol Colour Gold
MOT history of this vehicle
Test date 10 October 2016 Expiry date 9 October 2017 Test Result Pass Odometer reading 7,126 miles MOT test number 2916 6803 5697
Test date 23 March 2015 Expiry date 22 March 2016 Test Result Pass Odometer reading 7,087 miles MOT test number 6463 7228 5078
Test date 13 March 2015 Test Result Fail Odometer reading 7,083 miles MOT test number 8770 5237 5008 Reason(s) for failure
Nearside Front position lamp(s) adversely affected by the operation of another lamp (1.1.A.3f)
Nearside Headlamp not working on main beam (1.7.5a)
Windscreen wiper not operating automatically when switched on (8.2.1b)
front brake binding (3.7.B.1)
Test date 15 October 2013 Expiry date 14 October 2014 Test Result Pass Odometer reading 7,067 miles MOT test number 4291 4818 3211
Test date 12 September 2013 Test Result Fail Odometer reading 7,067 miles MOT test number 1388 6505 3289 Reason(s) for failure
Nearside Headlamp aim beam image obviously incorrect (1.8.A.1b)
Offside Headlamp aim too high (1.8)
Rear fog lamp tell tale not working (1.3.1b)
Hazard warning switch insecure (1.4.B.1d)
Windscreen washer provides insufficient washer liquid (8.2.3)
Registration plate lamp not working (1.1.C.1d)
Nearside Seat belt anchorage prescribed area is inadequately repaired (5.2.6)
Exhaust has a major leak of exhaust gases (7.1.2)
Fuel pipe insecure (7.2.1)
Nearside front brake binding (3.7.B.1)
Offside front brake binding (3.7.B.1)
Test date 4 September 2012 Expiry date 3 September 2013 Test Result Pass Odometer reading 7,018 miles MOT test number 3099 7804 2491 Advisory notice item(s)
all front suspension bushes cracking
o/s/f chassis cross member prescribed area repaired but not inappropriatly
Test date 25 May 2012 Test Result Fail Odometer reading 7,008 miles MOT test number 6176 3604 2126 Reason(s) for failure
Nearside Rear Rear position lamp(s) not working (1.1.A.3b)
Front Windscreen washer provides insufficient washer liquid (8.2.3)
Nearside Rear Suspension spring mounting prescribed area is inadequately repaired (2.4.A.3)
Offside Rear Suspension spring mounting prescribed area is inadequately repaired (2.4.A.3)
Nearside Front Suspension spring mounting prescribed area is inadequately repaired (2.4.A.3)
Nearside Outer Rear Suspension spring mounting prescribed area is inadequately repaired (2.4.A.3)
Offside Outer Rear Suspension spring mounting prescribed area is inadequately repaired (2.4.A.3)
Offside Inner Front Brake actuating linkage mounting prescribed area is inadequately repaired (3.3.A.2)
Nearside Front Brake hose ferrule excessively corroded (3.6.B.4e)
Offside Front Brake hose ferrule excessively corroded (3.6.B.4e)
Nearside Rear Statutory seat belt missing (5.1.1)
Offside Rear Statutory seat belt missing (5.1.1)
Offside Front Subframe mounting prescribed area repaired, but not inappropriately (2.4.A.3)
on retest welding needs inspection without under seal
Test date 29 September 2010 Expiry date 28 September 2011 Test Result Pass Odometer reading 6,969 miles MOT test number 4427 1287 0249 Advisory notice item(s)
Nearside Front wheel bearing has slight play (2.5.A.3c)
Offside Front wheel bearing has slight play (2.5.A.3c)
Offside Front Exhaust has a minor leak of exhaust gases (7.1.2)
Offside Rear Exhaust has a minor leak of exhaust gases (7.1.2)
Test date 25 August 2009 Expiry date 4 September 2010 Test Result Pass Odometer reading 6,601 miles MOT test number 8309 5773 9272
Test date 25 August 2009 Test Result Fail Odometer reading 6,601 miles MOT test number 3331 9703 9219 Reason(s) for failure
Test date 21 August 2008 Expiry date 4 September 2009 Test Result Pass Odometer reading 3,668 miles MOT test number 7436 8413 8260 Advisory notice item(s)
Test date 5 September 2007 Expiry date 4 September 2008 Test Result Pass Odometer reading 2,931 miles MOT test number 8445 6854 7201 Advisory notice item(s)
gewneral corrosion throughot chassis and body
Test date 21 July 2006 Test Result Fail Odometer reading 2,924 miles MOT test number 5319 2220 6284 Reason(s) for failure
Offside Rear Brake pipe excessively corroded (3.6.B.2c)
Nearside Rear Exhaust has a major leak of exhaust gases (7.1.2)
Nearside Rear Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
Offside Rear Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
Offside Front Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a)
Nearside Front Brake hose slightly deteriorated (3.6.B.4d)
Re: 3.0 Ghia
Hi Paul,paulda wrote:http://www.carandclassic.co.uk/car/C800301
Looks tidy - anyone on here know this Capri?
I stumbled upon this by accident, if it's any help to you?
http://www.ebay.co.uk/itm/ford-capri-3- ... 4d30ddd210
Still a private seller, and still has one previous recorded keeper, yet the Ebay seller was in Bristol.
Re: 3.0 Ghia
Hi Andrew - fascinating what can be found with a little effort - so in fact it's now 2 owners not one as stated in the current advert unless the chap from Bristol didn't sell it and relocated to Manchester.Andrew 2.8i wrote:Hi Paul,paulda wrote:http://www.carandclassic.co.uk/car/C800301
Re: 3.0 Ghia
Wow! Looks like lots been going on over the last few yearsandyd wrote:MOT history and mileage;paulda wrote:Think you're right Andy - one of my favourite colours too - I know what you mean about auto though being a Ghia model think it works quite well - wonder what the mileage is -andyd wrote:Hi Paul,
Andy
Re: 3.0 Ghia
Good find Andrew,Andrew 2.8i wrote:Hi Paul,paulda wrote:http://www.carandclassic.co.uk/car/C800301
The bodywork will explain the recent top half repaint. Was it done to a good standard????
MOT history would suggest it may have had a few botched welding repairs in the past?
Only became aware of this MOT site earlier this year, and I must say it has put me off quite a few cars since
Although as we know some testing stations will be more harsh than others so it is still a bit of a guessing game.
Its still an old car at the end of the day.
Andy
Re: 3.0 Ghia
Hi Paul,paulda wrote: unless the chap from Bristol didn't sell it and relocated to Manchester.
As chance would have it, I bumped into the chap at one of the Queen Square meets in Bristol. He was there with another car he was selling, another Capri, that can be seen in the background in one of the photos in the Ebay listing.
I seem to recall he was a trader, so he wouldn't have been that original owner anyway. Perhaps he sold it to another trader? The car hasn't been driven very far in the year and a half since it was last sold, as you would expect it would have done, had it been bought by a private buyer.
Re: 3.0 Ghia
Hi Andy - is the site you mentioned the dvla mot history check? I've used that and like you, it can be a little off putting what's gone on over the years - having said that, if what was wrong on the car has been properly fixed or they have been small things like, headlight not aligned correctly or its just been a matter of replacing a bulb then not so much of an issue - btw I may have something tasty coming in the next few weeks I found via a friend of a friend - watch this spaceandyd wrote:Good find Andrew,Andrew 2.8i wrote:Hi Paul,paulda wrote:http://www.carandclassic.co.uk/car/C800301
Andy
Re: 3.0 Ghia
Hi Paul,
Yes that's the site. People can't hide the truth anymore......Talk about what you don't know doesn't hurt you
I agree if money has been spent and repairs are done properly But the word Corrosion scares me .
Cant wait for your new purchase update
Andy
Andy
- Car(s): 1979 Ford Capri MKIII 2.0 Ghia - Apollo Green
Re: 3.0 Ghia
I do recall this when it was on eBay during the summer, it was about the £6-£7k if my memory serves me correctly as a buy it now.
Re: 3.0 Ghia
Yep and with the option to pay with debit / credit cards so guess it's still with a traderandyd wrote:Now on http://www.ebay.co.uk/itm/1981-FORD-CAP ... Sw8w1YB8Qq
Re: 3.0 Ghia
The way the description has been set out and worded = Dealer.paulda wrote:Yep and with the option to pay with debit / credit cards so guess it's still with a traderandyd wrote:Now on http://www.ebay.co.uk/itm/1981-FORD-CAP ... Sw8w1YB8Qq
Will be interested what it ends at. Currently 23 bids £6850 and reserve met!
Re: 3.0 Ghia
Hi All,andyd wrote: The way the description has been set out and worded = Dealer.
At least the dealer has set a realistic reserve and isn't asking silly money.
Currently at £7100, by the way.
Re: 3.0 Ghia
Hi Andrew.Andrew 2.8i wrote:Hi All,andyd wrote: The way the description has been set out and worded = Dealer.
With the car and classic advert at £11495, I thought they would have had at least a £10K reserve
Andy
Re: 3.0 Ghia
Listing ended!!
