Hi, I'm looking for the headlight relay that sits under the bonnet.
Mines gone kaput and there are only a couple on ebay but they are for auction not 'buy it now'.
Cheers.
Headlight relay Capri mk3
Re: Headlight relay Capri mk3
Sorry if you`re already aware, but you know there are fuses underneath where the cables plug in? You`re sure they`re not the problem? Apologies again if you knew this. If it IS the relay, try Martin at Caprigear: Tel: +44 (0)1507 343148 (workshop)
- Car(s): Capri 2.0 Laser - Daily Driver
Yeah I'm aware, the fuses are alright unfortunately. Thanks for replying though!
Alex I've messaged you. I have a MK2 and MK3 Relay on E Bay at the moment but I have others available.
- Dallas
- Car(s): Ford Capri 1.6 Laser. MG TF 135 BRG. MG ZT 190 V6. Dacia Sandero Stepway.
Try cleaning the contacts, mine were corroded and a bit of WD40 solved the problem.
- Car(s): I have got a 1981 3000s and I have just got my self
A 1987 2.8i thay are both red
I also have had motor bikes I have a 1200 Suzuki bandit - Contact:
Hi have you sorted out a headlight relay. I have several inbox me if you need one thanks mark
