Wanted - dip stick and oil filler cap
jrooney1991
Car(s): Ford Capri 1.6 Laser - Very much a project!
Post by jrooney1991 » Fri Aug 09, 2019 8:06 pm
After the cam cover oil cap and dipstick for a 1600 laser pinto please!
James Roooooooooooooooooooney!
http://www.clappedouttoclassic.blogspot.co.uk
Have a quick look at my Capri's ongoing restoration! You might teach me something!
Re: Wanted - dip stick and oil filler cap
Post by D366Y » Sat Aug 10, 2019 8:00 am
Have you tried the usual places?
Failing that there are a couple on :ebay: for bith items you're after, though the prices seem to vary a fair bit...
jrooney1991
Post by jrooney1991 » Sat Aug 10, 2019 7:06 pm
Good shout! Found an oil filler cap (NOS as well!) but there appears to be two lengths of dipstick... anyone know which is which? I can’t see why they would vary between the pintos...
Post by Peter-S » Sat Aug 10, 2019 9:29 pm
I believe that the 2.0 is a slightly taller engine so presumably you need the shorter dipstick for your 1600
Post by Jasonmarie » Sun Aug 11, 2019 12:08 am
Do you mean the dipstick is bigger on the 2.0 pinto :lol:
Post by pbar » Tue Aug 20, 2019 6:28 am
My dipstick tube has always been loose, is that normal?
Post by stevemarl » Tue Aug 20, 2019 2:25 pm
I believe they can be pulled out so I guess loose would be possible but probably not `normal` as such? Thinks: if it can be moved up/down how do you know correct position so the stick dips correctly, is there some kind of stop/step?
(Unless I just mistook a "Carry-on" moment :lol: )
Post by pbar » Wed Aug 21, 2019 6:36 am
I've never moved it up and down as such (insert Sid James laugh here), but I can easily rotate it both ways. I have read the same on here from other members too, but always thought it never seemed quite normal.
