Wanted-MK3 capri brake servo
Cowen99
Car(s): Capri mk1
Post by Cowen99 » Mon Mar 11, 2019 11:56 am
Looking for a MK3 capri brake servo?has to be a 2.0l or 3.0 MK3 capri servo
Re: Wanted-MK3 capri master cylinder
Post by Peter-S » Tue Mar 12, 2019 9:32 am
Cowen99 wrote:Looking for a MK3 capri master cylinder?
You will need to specify which model you are after as they are not the same across the Capri range but best bet might be CCI as they have been selling properly refurbished units on an exchange basis
Post by Not_Anumber » Tue Mar 12, 2019 11:45 am
Its worth doing a search on this and the other forum for fixes and workarounds for master cylinders. Some of the cylinders aren't widely available and I think Granada master cylinders were being used as a replacement on the 2.8i, they fit the same but are slightly larger which is thought to be a good thing. The search feature is your friend.
Sean007
Car(s): Ford capri 1.6 laser 1986
Ford capri 2.8i 1986
Ford capri 2.0s 5spd 1985
Post by Sean007 » Tue Mar 12, 2019 12:16 pm
I have a 2.0 master cylinder and servo if your interested been in the shed a while though
Cowen99
Car(s): Capri mk1
Re: Wanted-MK3 capri brake servo
Post by Cowen99 » Tue Mar 12, 2019 3:03 pm
Pmd
