Can anybody help with the correct 22 tooth speedo drive gear for my 2.8i 5 speed.
Mine has been swapped out for the one used in the 2.0L as the diff ratio was also changed to 3.44. It's a very tidy car and I'm bringing it back to standard spec. Also looking for 3.06 crown wheel and pinion.
Many thanks
Peter.
22 tooth speedo drive for 2.8i wanted.
- Car(s): 1987 2.8 Special (weekend driver)
1971 1600 GT (restoration project)
Re: 22 tooth speedo drive for 2.8i wanted.
Hi Peter,Capri gold wrote:Can anybody help with the correct 22 tooth speedo drive gear for my 2.8i 5 speed.
Are you still looking for this part?
I still have the packaging from a genuine part that I bought some time ago. I searched for the part number on Google and to my surprise it looks as though it might still be available!
http://www.ebay.co.uk/itm/252794811528
It's a different colour than the one I bought, but that alone won't make any difference.
I would suggest that you use the part number (1546881) to confirm the fitment with your local main dealer.
I've just checked and Burton now list them as being in stock.
http://www.burtonpower.com/22t-speedo-d ... t9300.html
Re: Mk1 pre-facelift parts needed.
Thanks very much for your reply Andrew. I did manage to get a used one from Geartech. Great to see new are available though!
I do still need a couple of things;
1. Spare wheel hold down plate for pre-facelift mk1. Just to be clear though it's the 'u' shaped one used on the early rostyle wheels.The bolt head is recessed down inside the centre.
2. Opening rear quarter glass and latches for mk1 Capri. Obviously either facelift or pre-facelift, it doesn't matter.
3. Passengers Inner door handle surround liner for mk1 pre-facelift. This is the black plastic part that fits in behind the door handle and clips into the chrome die-cast alloy handle surround. It covers the screw that holds the handle surround in place.
Any help with these items would be greatly appreciated.
I'm pleased that you managed to locate a speedo drive gear.
As it's been eight months since your post I fiqured that you'd found one, but at least the info and llinks are here in case anybody else is looking for one in the future.
