i need one of those little plastic clips that hold the front window glass on to the mechanism.
its for a mk3 but might be the same on the mk2
one like a ball joint that slides on to the slider thing.
also after a rear axle from a 1.6 with diff.
and maybe a 4 speed bullet if price is right.
thanks
Gary
plastic window clip and diff
- Tickford Man
- Car(s): Tickford + 3 x 2.8i
Re: plastic window clip and diff
There are 2 sizes, the later type slightly bigger which is what you will probably have if its for the Laser. Measure the gap in the metal aril it fits into, off the top of my head, its about 13 - 14mm ish?
Some of the plastic inserts are square, some round, but the same size.
email me at [email protected], I can post one or 2 out to you...
