Having a clearout. If any of this is of any use to anyone give me a bell:-
2.8 Water pump and gaskets - new
2.8 cylinder heads - SOLD
Mk II front grille in good condition all fixing lugs intact and chrome good -SOLD
Selection of mudflaps no fixings:-
2 x with Ford blue oval (n/s and o/s) new
2 x with small ford embossed logo (n/s and o/s) -SOLD
3 x with large ford embossed logo (2 x n/s and 1 x o/s) - SOLD
2.8 Inlet manifold blasted and painted grey never fitted
2.8 Strut brace with lugs for gas rams- SOLD
2.8 Warm up regulator
2.8 - 2 x aux air devices
2.8 Top hose housing with thermotime switch fitted
2.8 Plenum chamber and throttle housing
2.8 Oil cooler
2.8 Distributor outer cover
2.8 Polished throttle housing
2.8 Cold start injector
2.8 Steering coupling shaft
Pair of rear halfshafts
Bosch K-Jetronic technical instruction manual
MkIII Tailgate grey wiper motor cover – couple of small cracks but hardly noticeable
2.8 Top end gaskets - cylinder heads, inlet manifold, rocker cover, valve stem seals, and few other ancilliaries.
MkIIIBumper end caps some have been painted but all could do with tidying up, no major marks or scrapes:-
Rear set – genuine ford
4 x f/n/s and 1 x f/o/s – pattern parts
2.8 Steering wheel and centre cap – non leather
2.8 Unipart plug lead set and coil to distributor lead, distributor cap – used
Mk III windscreen seal
2.8 Throttle cable - new
2.8 1 x alternator and 1 x power steering pump drive belt – both new
2.8 Rocker box covers, bolts clamps and pcv
2.8 Ignition coil – used working when removed
2.8 Polished ignition module
2.8 2 x temp senders – one new
2.8 Expansion tank cap – new non ford
2.8 Radiator cap – new gen ford
2.8 Alternator - working fine when removed
2.8 Power steering pump and tank – tank powder coated satin black
2.8 Coolant and air hoses – only removed to fit silicon hose set
2.8 Fuel metering head and air box – air box has bottom cut out.
Also have an original Ford Service Manual 1974 onwards – good collectors item
misc parts
misc parts
- Car(s): 1.6 bmw mini cooper(daily driver), capri 2.0s (restoration project)
Re: misc parts
do you have any rear bumpstops? also how much for the mk2 grille?
