Help with parts...............
Posted: Thu Nov 16, 2006 9:23 pm
by hillside280
I'm fitting a replacement oil cooler to the 280 and I need three new seals.
1. Cooler to engine block.
2. Filter housing to cooler
3. Seal inside the filter housing where the threaded extension passes through.
Does anyone know if these are still available?
Re: Help with parts...............
Posted: Thu Nov 16, 2006 11:00 pm
by computershack
Yes they are. I had the cooler to engine block one fail on my capper just before Xmas. Didn't half throw the oil out quick. They're still on Ford parts list. Failing that, the O rings are the same size as the ones on the oil filters.
Posted: Fri Nov 17, 2006 10:15 am
by hillside280
Any idea of part numbers?
Posted: Fri Nov 17, 2006 11:11 am
by computershack
Sorry, no. I'm lucky that the bloke in the parts department at my local Ford dealership has been there since they brought out the Model T. Spot on bloke. Once when I needed a thermostat housing for a 2L Capper, he ordered a Sierra one as a Capri one was EOL and automagically ordered the pukka blanking kit for the extra pipe connector to go with it without needing to be asked.
hey conor you need the following..................
Posted: Fri Nov 17, 2006 12:27 pm
by partsguru280
cooler to enigne 1579875
filter to cooler 1023905
o/f extension 6026275(nut seal)
" 6100041
" 1023905
you should find m.w.r. keep em all matey if it helps.
cheers
chris
sorry should read hey 280
by partsguru280
doh!
chris
Posted: Mon Apr 16, 2018 6:37 pm
by Titan grau
Just running in to this stuff myself, while doing a little research I found the useful exploded diagram at the link below
http://www.fordopedia.org/parts-catalog ... 8-v6/A3.30
Also found, a very similar copper washer is availalbe from Simply Bearings Ltd simplybearings.co.uk
Posted: Thu Apr 19, 2018 7:12 pm
by nigecapri
Good shout there Titan grau,
Circulating links like that will be a valuable help to other owners.
Cheers.
