Help with parts...............
hillside280
Postby hillside280 » Thu Nov 16, 2006 9:23 pm
I'm fitting a replacement oil cooler to the 280 and I need three new seals.
1. Cooler to engine block.
2. Filter housing to cooler
3. Seal inside the filter housing where the threaded extension passes through.
Does anyone know if these are still available?
computershack
Re: Help with parts...............
Postby computershack » Thu Nov 16, 2006 11:00 pm
Yes they are. I had the cooler to engine block one fail on my capper just before Xmas. Didn't half throw the oil out quick. They're still on Ford parts list. Failing that, the O rings are the same size as the ones on the oil filters.
hillside280
Postby hillside280 » Fri Nov 17, 2006 10:15 am
Any idea of part numbers?
computershack
Postby computershack » Fri Nov 17, 2006 11:11 am
Sorry, no. I'm lucky that the bloke in the parts department at my local Ford dealership has been there since they brought out the Model T. Spot on bloke. Once when I needed a thermostat housing for a 2L Capper, he ordered a Sierra one as a Capri one was EOL and automagically ordered the pukka blanking kit for the extra pipe connector to go with it without needing to be asked.
partsguru280
hey conor you need the following..................
Postby partsguru280 » Fri Nov 17, 2006 12:27 pm
cooler to enigne 1579875
filter to cooler 1023905
o/f extension 6026275(nut seal)
" 6100041
" 1023905
you should find m.w.r. keep em all matey if it helps.
cheers
chris
partsguru280
sorry should read hey 280
doh!
chris
Titan grau
Car(s): 2.8i Special Mercury Grey over Stratos Silver
Postby Titan grau » Mon Apr 16, 2018 6:37 pm
Just running in to this stuff myself, while doing a little research I found the useful exploded diagram at the link below
http://www.fordopedia.org/parts-catalog ... 8-v6/A3.30
Also found, a very similar copper washer is availalbe from Simply Bearings Ltd simplybearings.co.uk
nigecapri
Postby nigecapri » Thu Apr 19, 2018 7:12 pm
Good shout there Titan grau,
Circulating links like that will be a valuable help to other owners.
Cheers.
