Pressure regulator experience
tommyroland
Car(s): Ford Capri 2.0 Laser and 2.8 Injection
Post by tommyroland » Fri Oct 01, 2021 3:32 am
Hi, Does anyone here know the supplier of the pressure regulator? I'm having problems with hot start, changing almost everything, before starting on the injectors.
Or have experience with this for advice? Thanks!
Re: Pressure regulator experience
Post by Peter-S » Fri Oct 01, 2021 7:16 am
You mean the warm up regulator? You can get rebuild kits, fairly straight forward job
https://www.ebay.co.uk/itm/383570487068 ... %3A2334524
Noel
Car(s): Capri 2.8i
M140i
Post by Noel » Fri Oct 01, 2021 10:10 am
Recon one listed in stock here:
https://www.motomobil.com/en/products/f ... 60518712-2
Or ask Southern Carburettors:
http://www.southerncarbs.co.uk/
ollyw
Post by ollyw » Tue Oct 12, 2021 9:36 pm
Do you need any special sealants Peter?
I bought one recently and intend to do the job over the winter. The German seller has yet to write any instructions.
I ask this as I also did a fuel distributor rebuild and for that I had to stick a bit of loctite (555?..) petrol proof sealant round the edge of the gasket. Worked a treat though as it was a seized item which I brought back to life at a reasonable cost.
Post by Peter-S » Fri Oct 15, 2021 11:28 am
No sealants on this one Olly
ollyw
Post by ollyw » Sun Oct 17, 2021 7:55 am
Great thankyou!
