Electronic ignition
- Car(s): drive 73 yellow 1300 facelift with a 2000cc engine
and a 76 V W beetle - Location: Shrule Co Mayo, Ireland
Electronic ignition
I know I asked this before but I can find where I recorded the answer I am having trouble starting my 73 facelift Its an ignition problem can any one recommend a good quality Electronic ignition and where can i purchase it Michael
Re: Electronic ignition
I haven't got any first-hand experience, but if it helps, Aldon were recommended to you in the replies to your earlier question.
https://www.aldonauto.co.uk//category.aspx?CID=1
Andrew Many thanks for your help ml
Hi shrule
shrule wrote,
It's very easy to fit and simply replaces the points and condenser.
Should you get one and need any tips in fitting it, please ask.
Regards,
Steve.
shrule wrote,
I bought one from, www.accuspark.co.uk and I'm very pleased with it and their help.can any one recommend a good quality Electronic ignition and where can i purchase it Michael
Regards,
Steve.
- Car(s): 3.0 Ghia
Mine is a Bestek setup
https://www.bestekuk.co.uk/gallery
..you get a distributor, module and also a Cosworth coil pack, does away with the ballast resistor and converts it to 12V continuous feed. Standard, fast road, race and rally setups available. Rally for me
I've got an Aldon in mine and it works a treat. Fit and forget as they say. I know Nick has one too and so did someone else but can't remember who.Andrew 2.8i wrote: ↑Fri Sep 10, 2021 3:48 pm I haven't got any first-hand experience, but if it helps, Aldon were recommended to you in the replies to your earlier question.
I bought an accuspark kit first but it refused to work. Might be that I just had a faulty one rather than the general quality of them is poor though as I know a lot of other people use accuspark without issue
Oh that reminds me, I had one of those too. Never had any problems with it although I have heard it gives a weak spark. If true, in practice, it wasn't noticable.Andrew 2.8i wrote: ↑Fri Sep 10, 2021 3:48 pm I haven't got any first-hand experience, but if it helps, Aldon were recommended to you in the replies to your earlier question.
