Fan belts from Tickover
Bud6200
Car(s): 85 Laser 2.0 just acquired ...to be for days out and the odd daily drive
Post by Bud6200 » Sat Apr 03, 2021 9:25 pm
I have just taken my first delivery from Tickover and the fan belts are branded Gates.
Now I don't have a problem with that , someone has to make them and the quality is good by the look and feel of it.
But ....I am sure it is way too short ... or is it me being a bit slow for want of a better way of putting it...alternator set at absolute minimum and still can't get it anywhere near...must be at least an inch short to get it near the lip of the pulley.
Has anyone else had these belts ...what was your outcome ?
:banghead: :banghead: :banghead:
Regards Paul
Re: Fan belts from Tickover
Post by Andrew 2.8i » Sun Apr 04, 2021 6:13 am
Gates are known as a good quality brand.
I wouldn't think for a moment that you've been supplied an incorrect part by Tickover, they know their onions, but what part number is the one you've got?
Don't forget that the belt will appear too small as you have to get it over the lip of the pulley...
Post by andyd » Sun Apr 04, 2021 8:04 am
I had issues when I did mine, there are 2 sizes;
Gates 6219MC 975mm
Gates 6267MC 988mm
Tried them both and went with the 988mm but still a right pain in the a**e and still had to remove alternator :(
Post by Andrew 2.8i » Sun Apr 04, 2021 8:59 am
Gates 6219MC 975mm
Gates 6267MC 988mm
Don't forget the OP has a 2 litre.
Tickover show the 6263MC, which is 865mm, as the belt they supply for the 2.0.
According to the manufacturer's website, that is the correct part.
Post by andyd » Sun Apr 04, 2021 9:09 am
Gates 6219MC 975mm
Gates 6267MC 988mm
Hi Andrew,
I just realised I didn't read the post properly :whistle:
Post by stevemarl » Sun Apr 04, 2021 10:17 am
:agree: that`s the correct size, the Bosch part is even tighter at 864 ;)
There must be something wrong if you need to take the alternator off to change the belt, surely, I never have?
Post by Jasonmarie » Sun Apr 04, 2021 4:41 pm
I can confirm that is the correct size as I have that belt fitted on mine what Tickover did 2 years ago . But wait a question is your engine the original ? Or was your laser originally a 1.6 ?
Post by Andrew 2.8i » Sun Apr 04, 2021 5:06 pm
Same engine though, isn't it? I'm no expert but I would wager that both the 1.6 and 2.0 pinto engines use the same size belts.
Post by stevemarl » Sun Apr 04, 2021 5:13 pm
Correct. The 2.0 block`s a couple of mm taller but doesn`t affect the alternator/water pump.
Post by Jasonmarie » Sun Apr 04, 2021 8:31 pm
I only ask as I think the 1.6 has a different alternator to the 2.0 one
Here’s a picture with mine , it also shows the right part number .
Post by Mr B » Sun Apr 04, 2021 8:58 pm
Can't you all just belt up :xd:
Post by stevemarl » Sun Apr 04, 2021 9:10 pm
AFAIK all the Pintos had the same alternator, why wouldn`t they, electrically they`re identical. There were different makes fitted, depending on supply chain, but they would all have the same diameter pulley so they run at the same speed.
Post by Andrew 2.8i » Mon Apr 05, 2021 6:28 am
Why all the interest in the size of David Gates' (or is it Gareth's?) belt anyway?
Apologies to anybody who was expecting a sensible contribution to the discussion. :lol:
Post by Jasonmarie » Mon Apr 05, 2021 9:35 am
You could have a point perhaps with the lock down the pinto engine has added a few inches :lol:
Post by stevemarl » Mon Apr 05, 2021 10:08 am
If your parting with your bread you want the right part ;)
Post by Andrew 2.8i » Mon Apr 05, 2021 12:00 pm
Wahey....excellent! :D
Bud6200
Post by Bud6200 » Mon Apr 05, 2021 5:02 pm
Yeah the one I ordered was the 6263MC, and on their site (Tickover) it lists it as being suitable for both 1.6 & 2.0 .
The one currently on is a Quinton Hazel 914.
Might just have to put it on the rack and pre stretch it :lol: .
If it still won't go on I may just have to get a slightly longer one if I can't get this one on with a jemmy bar.
Post by stevemarl » Mon Apr 05, 2021 5:17 pm
There`s something weird about this: the one fitted is (in theory) too big at 914mm, 50mm longer than the `correct` part. Although it would only be a 15mm increase in actual diameter. Very strange. Please don`t be offended but you have loosened fully so the alt will push right back, it`s not binding? Other than that, yes, get another 912 from a motor factors.
Bud6200
Post by Bud6200 » Mon Apr 05, 2021 6:09 pm
Yeah loosened off completely...It was seized , and snapped a lower collared bolt getting it off, but everything freed off and the alternator taps up against the block quite easily . :?: :?: :?:.
The old belt is quite Knackered ... lost more teeth than Nobby Stiles ... :lol:
