Replacement heater motor
[email protected]
Car(s): 2.0 laser mk3
Post by [email protected] »
Hi all. I replaced heater motor, installed a brand new one. Put wires on and it spun ok. Now I have put matrix back in you can't tell if the fan is spinning. Checked wires still attached but nothing Coming out of vents. Is it because I haven't topped up fluids yet?
Where have I gone wrong? Heat lever moves ok, but direction lever is very stiff. Disconnected hoses but still can't feel anything.
Ideas anyone?
Re: Replacement heater motor
Did you replace the old motor because it didnt work ? If you still have it ,might pay to hook it up to a battery and verify that it is actually crook . Maybe you have an issue getting power to the motor. Was the speed resistor ok ? I think that even if all the air hoses were blocked you'd still hear the motor if it was going . Stiff controls are something you should sort , sometimes all that is needed is a dribble of wd40 along the cable outer and the lever pivots . 😀
[email protected]
Hi, old motor was siezed up. I think one of the direction vanes may have misaligned when I put 2 halves back. But I should have air flowing in some direction.
Post by stevemarl »
Stating the obvious, but if the 0ld motor was seized the fuse will have blown: have you checked fuse 5?
[email protected]
Will check fuses again
