Essex V6 running temperature
capri3fan
Car(s): fiesta runabout, motorcyle for rush hour, looking for a 3.0 capri
Post by capri3fan » Sun Feb 21, 2021 11:51 pm
Can anyone tell me what the normal running temperature for the 3 litre Essex V6 engine is in degrees Celsius please?
I have after-market sensor and gauge in my car, so no red zone to guide me. I'm not a mechanic but believe may have thermostat problem as the top hose remains cold.
Manual says thermostat starts to open at 85 degrees with it fully open at 102 degrees. Does that mean it's ok for engine to be running at over 100 degrees C?
Many thanks.
Re: Essex V6 running temperature
Post by stevemarl » Mon Feb 22, 2021 9:40 am
Not really sure, but as it`s pressurised it will stand a bit over 100`c without boiling, but that`s more an occasional, hot day, steep hill type of thing. I`d have said ideally about 90 - 95ish ? Thermostats are cheap, if you`re concerned just stick another one in.
Post by Mc Tool » Tue Feb 23, 2021 7:38 pm
Another valuable diagnostic tool ......thats fun to play with 😁is one of them digital laser thermometer things , and they are getting cheaper too . It would be ideal for t/stats as twould be easy to test temp either side of the stat without sticking your fingers in the fan ( that never happened to me 🙄) .
