Rear springs 1.6 laser
- Car(s): ford capri 1.6 laser mk3 1987.
Hello.
The back end of my car looks a bit tired. It has multi leaf springs. Been looking around the spares that are advertised and i have not seen multis for sale. do i convert to singles ? Any advice appreciated.
Re: Rear springs 1.6 laser
I'd stick with the multi leaf, you can get them, this company has them, although expensive so I'd definitely shop around first.
https://www.burtonpower.com/leaf-spring ... r3900.html
Think you can get them here too -
https://britishclassiccarparts.com/coll ... ord?page=3
These are reasonably priced, 1/3 of Burtons, and a good make:
https://www.ebay.co.uk/itm/KILEN-622000 ... SwO7haGWYn
- Car(s): I have got a 1981 3000s and I have just got my self
A 1987 2.8i thay are both red
I also have had motor bikes I have a 1200 Suzuki bandit - Contact:
Hi I have a pairs of spring. I have got single and I think I have a pair of Multileaf -as well
Good one Steve. I used new Kilen coil springs for the fronts and they were spot on, never thought to check for their rear springs too.stevemarl wrote: ↑Sun Feb 21, 2021 6:21 pmThese are reasonably priced, 1/3 of Burtons, and a good make:
There is an exellent how-to on changing the rear springs from this forums owner, here -
http://www.fordcaprilaser.co.uk/page142.html
I bought new multi leaf springs for my Mk1 here a couple of years ago, if I remember correctly they are are manufactured
by Owen Springs in the UK. Good communication from them too regards questions and double checking measurements etc. They also sent the bushings separate and not installed as I said I was using poly's and did not want to have to remove them so saved hassle there. It may be an option anyhow.
https://britishclassiccarparts.com/search?q=capri
I'll say the names.... and you say yes or no. Nightrider. Toecutter. Bubba Zanetti!Toecutter wrote: ↑Tue Mar 02, 2021 9:45 pmI bought new multi leaf springs for my Mk1 here a couple of years ago, if I remember correctly they are are manufactured
