What's this! Where can I get new one
Hi so I broke this today, and was wondering where i can get new one from or do i need it help would be much appreciated thanks
Gos to bottom of manifold
Re: What's this! Where can I get new one
Isn't this temperature sensor?
Check the markings and try burton power.
https://www.burtonpower.com/catalogsear ... ure+sender
At least it looks little bit same.
Know this has 2 pipes comeing off it and gos to bottom of inlet manifold
It looks like part of the emissions crap fitted to later pinto engined cars like Sierras. You don't need any of it but you will need to put that or another bolt in the manifold to seal the hole
Thanks cheers
My guess is, looks like a cold start idle-up air valve throttle bypass thing , goes into the coolant jacket and closes off as the coolant heats up ........cant think whats is called
could be for the emissions too Peter-S , like a vacuum air valve ,def coolant temp activated.
than a frontal lobotomy
Better pic
Foley...... we shoulda known it was you.
Ah yes , I can see the two pipes much better now
Well, recycling is fashionable these days....
viewtopic.php?f=14&t=46102&p=298501&hilit=foley#p298501
Andrew 2.8i wrote: βSat Feb 13, 2021 10:51 amWell, recycling is fashionable these days....![]()
https://youtu.be/n-aTFfqEOOk
Hamish its called "a cold start idle-up valve throttle bypass thing"
Ah!, There you see , one should never underestimate a bus driver, like hairdressers ......amazing what they know
