Ignition coil
- Car(s): Ford Capri 2.0 Laser (Daily Driver)
Ignition coil
After an ignition coil for my mk3 capri 2.0 pinto.
Anyone k ow what the best one to go for is?
Re: Ignition coil
There are a few choices ,depending on wether you still have points , off road vehicle (epoxy filled coil for rough treatment ) ? ballast or not ? and where you buy from but generally bosch msd or ngk are a good bet .
than a frontal lobotomy
Re: Ignition coil
Simply pop into your local Ford dealership and produce the warranty card, receipts and service book for the correct replacement coil for your vehicle.
Re: Ignition coil
I`ve used one of these as I suspected I was getting a bit of tracking down the `tower` of the original 36 y.o. one. I`m sure there are any number of coils will do the job, but I can vouch for this:
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
(As Hamish pointed out, this would be for a points based, ballasted set up)
Re: Ignition coil
Tickover fitted mine a few years ago and it’s ok .
https://www.tickover.co.uk/shop/content ... /p645.html
Re: Ignition coil
That's what's there now. What type is that?
Re: Ignition coil
Lucas. Can you see any of the text, should say 12v or 6v: ballast, non-ballast? Or check the voltage across th LT terminals?
Re: Ignition coil
I'll take a look at what's left of the label when I get home see if there's any info left on it lol
Re: Ignition coil
If it`s any help, the 2 round plugs are the original fittings, the spade connectors have been added bt a previous owner (maybe a cut-out switch shorting the coil
) The voltage may be stamped on the bottom surface.
edit: just saw ur post. In that case, the coil I got from Amazon will just slot in. Assuming you`re sure it IS the coil? Those 2 spade connectors look ominous, where do they go? Can you get rid of them?
Re: Ignition coil
Not sure how much that helps!stevemarl wrote: ↑Mon Jan 25, 2021 2:20 pmIf it`s any help, the 2 round plugs are the original fittings, the spade connectors have been added bt a previous owner (maybe a cut-out switch shorting the coil![]()
Re: Ignition coil
They look like they go into the distributor, so my guess is maybe you don't have points, but one of the newer self-contained electronic set ups?
Re: Ignition coil
I got a Lucas DLB 120 on mine. The car is bog standard and the coil seems fine.
Re: Ignition coil
Alright I guess I'll play safe and just get the same one just wasn't sure if it was worth seeing if anyone found other ones better that would fit what I have
Re: Ignition coil
Do you have an electronic ignition in that instead of points?
I fitted an Aldon kit years ago and fitted a flamethrower coil at the same time
https://www.amazon.co.uk/PerTronix-4061 ... XOYE&psc=1
Re: Ignition coil
How can I tell if its electric ignition instead of points?Peter-S wrote: ↑Mon Jan 25, 2021 6:25 pmDo you have an electronic ignition in that instead of points?
Re: Ignition coil
Mrbaboon1985 wrote: ↑Mon Jan 25, 2021 7:27 pmHow can I tell if its electric ignition instead of points?Peter-S wrote: ↑Mon Jan 25, 2021 6:25 pmDo you have an electronic ignition in that instead of points?
Under your distributor cap there should be a set of points and a condenser on the outside ?
But now worried why your looking for a coil as you must have a fault ?
What’s wrong with your Capri then ?
Update
You have electronic ignition in that picture so yes a new coil is needed not sure about the wiring , did you fit the electronic ignition ?
Re: Ignition coil
Seems unlikely Jason if he's not sure of the difference!
I asked because the wiring and lack of condenser looked like it was electronic so possibly a dedicated coil for electronic might be a better option, depending on the problem of course.
Re: Ignition coil
Just starting to take a few turns to start over recently so wasn't sure if the coil might be on its way out. The leads and plugs all look recent just not the coil
