rear wheels fowling arches
Recently purchased a 1.6 Laser with nice alloys (not RS) and the rear tyres fowl the rear wheel arches when driven over rough roads.
The tyre size is 205x60R13 x86H. They are recent new tyres and wheels so reluctant to change,rear shocks and springs appear ok .
Any advice please?
Any advice please?
Re: rear wheels fowling arches
Are you sure there are no spacers behind the wheels to increase track? AFAIK the 2.8s had 205/60 so they should fit. Are they sticking out beyond the arches or just vertically too close? Pic would help.
A Steve says the 2.8 had that size tyre on the pepperpot wheels that were 7" wide, so should be ok!
As said, the size of the tyres won't be a problem in itself, but are they on aftermarket alloys?
What's the offset of those alloys?
I have 2.8 wheels with 205/60/13 on mine and they are fine ? I would say it’s your shocks or springs
OK, I had to ask: there are no birds under there? (Oh, please yourselves!)
As said by others you need to check the wheel offset. Additionally are there lowering blocks between the spring and axle - perhaps someone has seriously reduced the ride height?BSH wrote: ↑Sun Jan 10, 2021 1:21 pmHi,
Any advice please?
The other thing I would check is has the previous owner stuck spacers on?
ok Thank you,
I check it out asap and take some photos
Maybe he should try feathering the throttle
Are you sure contact between tyre and arch is the problem? Does it knock or does it make a sort of sound like a screechy bark?
- Car(s): 2.8 Injection 1983 5 speed, weekend car. Audi A7 during the week. Slowly restoring a 1979 MGB + a 1964 Honda 250 twin. Previously owned 2 Capris.
If what you say is true, he'll need to ditch the steering wheel and get a proper yolk.Not_Anumber wrote: ↑Mon Jan 11, 2021 6:01 pmThat car will fly when the clearance problem is sorted and the owner will be eggstatic
Could just be the tyres. Get rid of the Goodyear Eagles
Did you get it sorted my good man?
Thanks to all replied not sorted yet but will look into it shortly.
Some photos and would help. Are you sure the wheels are the correct offset ?
