The problem is that i might need to rise/get rear axle higher. What is the best way to do it?
Is the available height ajustable rear shock absorbers/springs?
(The reason is that I ordered a set of Calvert low-profile Caltracs and they reduce my rear height by 3,5")
Ford Capri Mk1 72-> adjustable rear shock/springs.
- Car(s): 2.8 Injection 1983 5 speed, weekend car. Audi A7 during the week. Slowly restoring a 1979 MGB + a 1964 Honda 250 twin. Previously owned 2 Capris.
Re: Ford Capri Mk1 72-> adjustable rear shock/springs.
Trolley jack and a pair of axle stands should do it
so funny.... It is hard to drive with axle stands.....
Take the cement bags out of the boot .
I have seen coil over shocks fitted with the leaf springs still in sutu , they are a bit of extra thats adjustable in both ride height and dampening ( if you get adjustable dampening shocks ) and there is the option to try different spring rates . Wether you use springs or air shocks to raise the back it will effectively stiffen up the rear springing, maybe to much ....in which case put the cement back in
you gotta make the most
out of your 20's, 30's, and 40's coz when you hit 50 the "engine check" light comes on.
I have these fitted
https://www.burtonpower.com/single-leaf ... ls230.html
Arc of that spring is lower and is same as 1,5" lowering kit with 2.8i leaf springs.
https://1drv.ms/v/s!Ak0ev910-aPV_GCdz5YFLlPZg8gz
Those single leafs are pretty much the same as 3 leaf normal springs.
