Hi just a little but of advice.
I've swapped my main headlights to BMW smileys. And they make a massive difference one appears to be not as "White" with the bulb in.
Could this be a faulty bulb as there both the same or am I going to have to take one back out and give the projector a good toothpaste clean?
Headlights
- Car(s): Ford Capri 2.0 Laser (Daily Driver)
Re: Headlights
Can you swap the bulbs ( do they come out of the light assy ?) from side to side and see if the dull light moves also , that way you could know if its the bulb or reflector
you gotta make the most
out of your 20's, 30's, and 40's coz when you hit 50 the "engine check" light comes on.
Re: Headlights
Seems to come out the fine just slightly off colour. One is a glorious bright white the other more of a tinge to it.
Re: Headlights
Same make and rating of bulb?Mrbaboon1985 wrote: ↑Mon Nov 30, 2020 7:41 pmSeems to come out the fine just slightly off colour. One is a glorious bright white the other more of a tinge to it.
Re: Headlights
Different make bulb. School boy error.
Tried everything but that basic check lol
