Air con
Air con
Did any of the later model Capris have air con factory fitted. I have a 3.9 serp motor with the air con compressor fitted and I figured may as well have air con if I can as it will be a pita to remove compressor and fashion some sort of idler pulley .
you gotta make the most
out of your 20's, 30's, and 40's coz when you hit 50 the "engine check" light comes on.
Re: Air con
Hi MC,
I bought a 3 litre Capri years ago that had A/C on it, not sure whether it was a factory option but the conversion was excellently done, the air con compressor/pulley was mounted between the water pump and alternator, inside the car the unit/air vents were just below where the ash tray is, really nice job,
Re: Air con
I was thinkin of using the side swivel outlets for the cool air, also thinkin I could fit a shuttle valve and turn the heater into a heating/cooling unit.......do away with the coolant side of things and fit the evaporator/condenser where the heater matrix is now
- T.M.
Re: Air con
if I´m right only Tickford Capri had originally A/C. But it wasn´t "factory" Capri too much.
Tom
Tom
Re: Air con
Tickford didn't have it as standard. Not sure if anyone ever specced it, but never been in one that did have it.
I seem to remember the older Haynes manuals showed an air-con set up, but it was a completely different heater unit.
I'd assume a more common option on the 'Federal' Capris over the pond with our colonial cousins?
Ask around and see who has that version of the Haynes manual to give you an idea what's needed.
All my 30+ Capris had the basic air-con. It was well ahead of its time as it could be changed between driver and passenger sides and each had their own controls. A simple rotary handle on the door card. Bit like a shower tap, the further you turned it, the cooler it got.
Re: Air con
I`ve got the Haynes but apart from some mention in dismantling the dash (apparently the `unit` is fixed to the lower RH dash - so the LH in a RHD car)Bug wrote: ↑Wed Nov 25, 2020 8:47 amI seem to remember the older Haynes manuals showed an air-con set up, but it was a completely different heater unit.
and the ccircuit diagram. No further info I`m afraid. Maybe look for Mercury Capri brochure? There was an American on Capripower, he might know.
EDIT:
found a bit more (in `bodywork` section!)
Re: Air con
I think you're right. Been years since I saw the manual and it appears I may have got confused with the HD heater assembly.
I'll get back in my box.
Re: Air con
Martin, no, to be fair - I had no recollection of it at all, so you must get at leastb 9.5/10
Re: Air con
All my 30+ Capris had the basic air-con. It was well ahead of its time as it could be changed between driver and passenger sides and each had their own controls. A simple rotary handle on the door card. Bit like a shower tap, the further you turned it, the cooler it got.![]()
Yeah , that might work in old blighty but it gets hot here
Re: Air con
Wow, who knew?
Has anybody actually seen a Capri with factory fitted A/C though?
As an aside, my Hayne's Manual makes no mention of air conditioning equipment.
- T.M.
Re: Air con
Yep, Tickford didn't have A/C on the option list either, like you say:Bug wrote: ↑Wed Nov 25, 2020 8:47 amTickford didn't have it as standard. Not sure if anyone ever specced it, but never been in one that did have it.
http://i786.photobucket.com/albums/yy14 ... kford3.jpg
So I was not right, sorry.
Tom
- snizeldelabmx
- Car(s): mk3 capri cabaret II
Re: Air con
Hi Andrew, i know one down here in south Spain, factory fitted AC in a late 2.8 and I have to say it cools great!!!Andrew 2.8i wrote: ↑Thu Nov 26, 2020 6:51 pmWow, who knew?
mi little work----> viewtopic.php?f=17&t=36637&p=241688#p241688
