Rear door card hole
Jumper
Car(s): Mk 3 1.6GL
Rear door card hole
Post by Jumper » Wed Nov 11, 2020 12:06 pm
Just bought a Mk 3 and the rear door cards have holes just behind the ash trays. Photos on line show some kind of clip - anyone know what these are?
Re: Rear door card hole
Post by Peter-S » Wed Nov 11, 2020 12:36 pm
Sounds like the clip to hold rear seta belts when not being used. Belts were only fitted to later Capris and if you have an interior from a later Capri you might have the holes but no belts. Happens a lot if Shark Grey seats from a 2.8 have been fitted in to a lower spec model.
Post by Bug » Wed Nov 11, 2020 2:54 pm
As far as I recall, even if you have belts in the rear (which may have been retro fitted as the mounts were all there), you will not have the metal bit behind the side panel that the clips screwed in to.
I fitted rear belts to a couple of my older ones and modified the side panel by reinforcing it with a biscuit tin lid of all things ( :D ), then fitting the captive nut thingummies into that so it wouldn't just pull through if someone was a bit rough trying to release the belt from its clip.
340truck
Car(s): Rat - GONE
Post by 340truck » Wed Nov 11, 2020 5:39 pm
Mk3? With rear doors? Never had one of those.
:sarcasmalert:
Post by Bug » Thu Nov 12, 2020 8:30 am
:sarcasmalert:
Now now Mr Truck!
I thought the same, but it's his first post......................be gentle. :xd:
Post by Mr B » Fri Nov 13, 2020 2:18 am
:sarcasmalert:
Decent looking Scania? never seen one of those either!
:sarcasmalert:
340truck
Car(s): Rat - GONE
Post by 340truck » Fri Nov 13, 2020 7:58 pm
Think they're horrible looking. Seats give you backache too.
That's a very old pic....drive a nice Renault now.
Jumper
Car(s): Mk 3 1.6GL
Post by Jumper » Sat Nov 14, 2020 4:26 pm
Ok, fair point, the cards below the rear windows.
Post by Major_Tom » Sun Nov 15, 2020 12:40 pm
Lets see a pic then!
