Rear ARB bush orientation
LaserSean91
Car(s): Golf GTI (Daily Driver)
Ford Capri 1.6 Laser (Restoration Project)
Post by LaserSean91 » Mon Sep 21, 2020 6:46 am
I have taken off my rear anti roll bar to paint and fit polybushes and there is one side of the bush that protrudes out of the 'eye' on the end of the threaded bar more than the other... Can someone confirm which way the bush goes? Thanks in advance :)
Re: Rear ARB bush orientation
Post by stevemarl » Mon Sep 21, 2020 10:24 pm
Is this any help?
LaserSean91
Post by LaserSean91 » Tue Sep 22, 2020 7:20 am
Thanks for the reply, your picture seems to have the standard bushes. My bushes I have used are different and seems protrudes one side of the eye more than the other. I can't seem to find any info on which way around to fit them.
Post by Bug » Tue Sep 22, 2020 8:07 am
That's odd that they are different colours for each half? And even the two axle ones are different colours.
Was this a conscious decision on your part?
Just wondering as I know one or two manufacturers denote different strength/hardness with different colours?
LaserSean91
Post by LaserSean91 » Tue Sep 22, 2020 8:08 am
It was a 'budget set' made up with odd colors. They are all the same hardness. Saved me £20 :lol:
Post by Bug » Tue Sep 22, 2020 8:09 am
It was a 'budget set' made up with odd colors. Saved me £20 :lol:
Ah ok, as long as they are all the same spec.
LaserSean91
Post by LaserSean91 » Tue Sep 22, 2020 8:16 am
Yeah all the same spec, Just a bit unsure which way around they go.
Post by stevemarl » Tue Sep 22, 2020 9:43 am
I would say just to test fit both ways and see which fits most snugly, (I`d guess long side outer). You`ll probably find one way obviously fits better?
Edit: I guessed right:
Noel
Car(s): Capri 2.8i
M140i
Post by Noel » Wed Sep 23, 2020 8:43 am
Yeah the thicker end of the bush that sticks out more goes against the chassis, i.e. pointing outwards as it were.
Should be 4 washers too that go one either side of the bush to spread the load across the insert and the poly material.
LaserSean91
Post by LaserSean91 » Thu Sep 24, 2020 7:44 pm
Cheers gents, thanks for clearing that up for me. Greatly appreciated. Hopefully it will be back on soon once I have sorted the spring hanger area.
