Not a Capri
Not a Capri
..05 Fiat Panda 1.2
Speedo is all over the place and under reading. Is there anything else I should know before I order a new cable? Like do these cars still use cables etc
Thanks in advance!
Thanks in advance!
Re: Not a Capri
Burn it.
I had an 07 plate Panda for about 5 years and it tried to kill me on multiple occasions - it's an evil car at heart and nothing can change that so I had mine crushed
Good luck fixing it!
Re: Not a Capri
Don't Panda to it's every whim!
To be honest Tom, I'm surprised you fit!
Re: Not a Capri
I also forgot to actually answer Tom's question:
Don't Know.
Re: Not a Capri
Sounds like a sticky cable . Can you pull the inner cable out and grease it up a bit ,usually works . Dunno about panda's but some cars the cable outer can fry if to close to the exhaust and then its custard
Re: Not a Capri
That age I'm certain it would be an electronic speedo.
Re: Not a Capri
It is indeed an electric speedo. All sorted now thanks gents.
Re: Not a Capri
Nothing did, it's not my car, I was just recommending something to a mate of mine
Re: Not a Capri
Did you take my advice and recommend he crush it?
Re: Not a Capri
It's a girl's first car, haven't got the heart to tell her to crush it
Re: Not a Capri
She sounds like the sensitive type, you'd better not tell her Danny thinks she is a he......
Re: Not a Capri
Is there another type other than sensitive?Andrew 2.8i wrote: ↑Sat Sep 12, 2020 8:55 amShe sounds like the sensitive type, you'd better not tell her Danny thinks she is a he......
Re: Not a Capri
You obviously need to meet the current Mrs Wells!Major_Tom wrote: ↑Sat Sep 12, 2020 9:04 amIs there another type other than sensitive?Andrew 2.8i wrote: ↑Sat Sep 12, 2020 8:55 amShe sounds like the sensitive type, you'd better not tell her Danny thinks she is a he......
Re: Not a Capri
I forgot I can't assume anyone's gender anymore upon pain of deathMajor_Tom wrote: ↑Sat Sep 12, 2020 9:04 amIs there another type other than sensitive?Andrew 2.8i wrote: ↑Sat Sep 12, 2020 8:55 amShe sounds like the sensitive type, you'd better not tell her Danny thinks she is a he......
Re: Not a Capri
God that's disgraceful assumption assuming.
