Capri gearbox oil leak
antonio31
Car(s): Ford Capri 1600 GT
Post by antonio31 »
Hello,
I have a problem with my gearbox (Ford Capri mk1 with 4 speed gearbox). I changed the rear oil seal and it still leaking through the propshaft (like in the photo). Is there any cover or something in that hole? I replace the oil from the gearbox and almost half has been gone from that area.
Thanks for your help.
Cheers!
Re: Capri gearbox oil leak
Seems odd to me , but if your sure thats where it's coming from. I would remove the yoke from the u joint and have a real good look at the end of the spline tube. It should be sealed off . I got a hazy memory that an old 3litre drive shaft I have has a disc welded over the end of that hole. Maybe clean it up ( looks ok) ,hold it open end up and tip a bit of crc in there to see if you can spot the leak , might be just a pin hole you could put a blob of weld on :)
Another thing to check is the sleeve in the rear of the gearbox. Put the propshaft back in and see if there is a lot of play in this. The bush/sleeve can be replaced so long as you can still get one for that gearbox type.
antonio31
Post by antonio31 »
Hello,
Thanks for your answers. I found a picture on Google and seems that I should have a plate in that hole. I checked on mine and there is nothing. I will try to weld something there.
Thanks again.
Regards,
Antonio
EightyFive
Car(s): Ford Capri 2.0 Laser 1985
Post by EightyFive »
Paul G wrote: Fri Aug 21, 2020 10:23 pm Another thing to check is the sleeve in the rear of the gearbox. Put the propshaft back in and see if there is a lot of play in this. The bush/sleeve can be replaced so long as you can still get one for that gearbox type.
I think this seems more likely, sounds like oil has dripped it's way down to the yoke and making it appear as if it's coming from the prop.
tejb1
W- Mondeo 2.0 Ghia Estate
03 Focus 1.6
Post by tejb1 »
Exactly that. My gearbox is always mildly incontinent, and it can look like a leaky diff as the oil travels some considerable way.
antonio31 wrote: Tue Aug 25, 2020 9:56 am Hello,
Thanks again.
Regards,
Antonio
Sounds like Antonio has found the problem guys .
Have to agree that oil from a leaking prop shaft seal travels a fair way , mine made it all the way to the rear number plate (oil spots all over the back of the car ,which were easier to see in all the dirt :whistle: ).....and the exhaust on the way there .....which explained the burning oil smell whenever I stopped in traffic
r2vdh
Post by r2vdh »
Fixed all the leaks on my car recently... Now I have no rust protection underneath :lol: :lol: :lol: :lol:
