Master cylinder reservoir
Post by Caprifan Rob » Wed Aug 12, 2020 10:09 pm
Had a refurbished Brake master cylinder fitted 2 years ago and it’s recently developed a leak on both reservoir seals. Have replaced seals & reservoir, does anyone know if this is how it should look as there’s a small gap between reservoir & seal. No amount of pressure seems to close the gap, just checking if this is normal as don’t want to damage it.
Thanks, Rob
Re: Master cylinder reservoir
Post by pbar » Thu Aug 13, 2020 6:05 am
Is that the 'correct' reservoir Rob, I thought the 2.8 one should look like this, for sale at the Capri Club -
Post by Caprifan Rob » Thu Aug 13, 2020 6:43 am
Hi Paul, yes all correct, bought it from Martin at Caprigear. May be the angle I took picture. Wanted to get the gap in view.
Post by pbar » Thu Aug 13, 2020 7:15 am
Okey doke Rob, yes I did think it may just be the angle, a bit like one of those 'what is it' pics, taken at unusual close up angles :) Hope you get it sorted soon.
STEVEW
Car(s): Ford Capri 2.3S
Project
Post by STEVEW » Thu Aug 13, 2020 7:28 am
Hi Rob
I’ve just checked our car (2.3S): the seals are flush. Although our master cylinder is not quite the same as yours I would think that the seals should sit without a gap.
Having said that, could it be you have an air lock in the system preventing full insertion of the reservoir?
My suggestion: lightly lubricate the seals with brake fluid and “crack” the brake lines open around the differential valve and try again.
Edited to add: I've just seen a seal kit advertised on Ebay which includes a sachet of, "Frentec Braking" red rubber grease so I guess this is the right stuff or something similar, to lubricate the seals before fitting.
Post by Mc Tool » Thu Aug 13, 2020 9:21 am
That set up looks fine to me . The thing seals on the spigots on the bottom of the resiviour .....not on the flat surfaces of the rubber seal and the bottom of the resiviour. :)
Post by Caprifan Rob » Thu Aug 13, 2020 1:56 pm
Cheers Paul, looks like all is ok.
Thanks for checking Steve, I know different engines have different cylinders, some flush reservoirs & some not :headscratch: . Did use brake fluid to help fitting & that's as close as I could get it, no leak now so hopefully sorted.
Thought as much, thanks Hamish. Checked recess in seal before fitting, just wanted to check before driving as brakes can be quite handy :cheers:
STEVEW
Project
Post by STEVEW » Thu Aug 13, 2020 5:17 pm
Thanks for the feedback Rob.
I'm pleased you seem to be sorted.
Post by Peter-S » Thu Aug 13, 2020 5:40 pm
[/quote]
Hamish doesn't really use brakes :lol:
Post by Caprifan Rob » Thu Aug 13, 2020 6:54 pm
I know Peter, I've seen the pictures ;)
Good luck with getting it sorted Hamish.
Post by Mc Tool » Fri Aug 14, 2020 12:12 am
I was waiting for that :xd:
