Mk3 rear seat
Garym280
Car(s): Ford Capri mk1 2.0 got and Brookline’s 280
Mk3 rear seat
Post by Garym280 » Thu Jul 09, 2020 6:30 pm
Hi, does anyone know how to remove the backs from the Mk3 rear seats, I’ve removed the nut from behind the flap in the carpet but can’t see what else to remove, thanks Gary.
Re: Mk3 rear seat
Post by Peter-S » Thu Jul 09, 2020 7:02 pm
That should do it. Just hold each side of the back near the bottom and give it a tug and it should come away.
Re: Mk3 rear seat
Post by Bug » Fri Jul 10, 2020 8:43 am
Yup, just pull it backwards until it clears the bolt, then lift it slightly as it slots onto the top of the frame.
If they've never been off before, you may even find the original build sheet still behind one. If memory serves it was usually on the righthand side.
Oh and just because I'm a pedantic git, it's a Brooklands 280, not a Brookline. ;)
Re: Mk3 rear seat
Post by Not_Anumber » Fri Jul 10, 2020 1:05 pm
I thought maybe a 'Brookline' might be a new term for a Special with 15" wheels. You know, in the same way as Fords new ST line, Mercedes AMG-line and Audi's S-line - to designate those cars have some of the styling from the full ST or AMG range etc :xd:
Re: Mk3 rear seat
Post by Bug » Fri Jul 10, 2020 1:54 pm
Ah no, Brookline is the name given to those unfortunate enough to be spun, ending up backwards in a shallow stream. The trajectory taken is known as the 'brook line'. :xd:
Garym280
Re: Mk3 rear seat
Post by Garym280 » Fri Jul 10, 2020 2:45 pm
Thanks for the reply’s, I’ve now got them off.
Re: Mk3 rear seat
Post by Not_Anumber » Fri Jul 10, 2020 3:11 pm
Thats a good stream of thought :cheese:
Re: Mk3 rear seat
Post by Bug » Fri Jul 10, 2020 3:58 pm
Good stuff.
Apologies for the leg pulling ;)
Did you find a build sheet?
340truck
Car(s): Rat - GONE
Re: Mk3 rear seat
Post by 340truck » Sat Jul 11, 2020 8:16 am
I just say "Cabbage"
Re: Mk3 rear seat
Post by Major_Tom » Sat Jul 11, 2020 9:21 am
Water way to hijack a thread.
