Accelerator cable and engine paint
Post by Mr B » Sat Jun 27, 2020 7:17 pm
Evening all,
Almost finished installing an Edelbrock carburetor on my 3 litre Essex engine, just need to adapt an accelerator cable to match the Capri pedal to the Edelbrock linkage, can anyone tell me what Capri had the longest accelerator cable, I'm thinking it's the 2.8i but I'm not totally sure tbh.
Also can anyone recommend a decent brand of engine paint please.
Cheers guys
Re: Accelerator cable and engine paint
Post by Caprigear » Sat Jun 27, 2020 10:19 pm
2.8i had the longest cable.
mjcapri
Car(s): Diamond White Mk3 Granada 24v
Caspian Blue Sierra XR4i
Stealth Grey Focus RS
Post by mjcapri » Sun Jun 28, 2020 6:34 am
Regarding the paint, it’s all in the prep. Give the block and anything else you’re painting a thorough clean and degrease and then prime it (I’ve found etch primer works fine on engines, U-POL is a brand I use). With the right prep any engine/high temp paint should be fine, I don’t paint the heads and rest of the engine doesn’t actually get that hot. There probably is a product suitable for use on heads these days, I’ve just never bothered to look!
Post by Mr B » Sun Jun 28, 2020 8:51 am
Thanks for the replies gent's, great information as ever, it's much appreciated.
A mate of mine has just suggested stove paint for the cylinder heads, any thoughts?
mjcapri
Post by mjcapri » Sun Jun 28, 2020 10:37 am
If you’re going to paint them I’d just use the same method as the block, you may well find it works ok. I’ve just never bothered painting them but actually I’d like to paint the heads off my Sierra as it’s a full resto so I’d be interested to see how successful it is (not using you as a Guinea pig honest!).
Post by stevemarl » Sun Jun 28, 2020 11:18 am
Your biggest problem will be the exhaust manifold as that gets far, far hotter than any other part, plus the expansion/shrinking, tends to make it tough for any paint to last. Otherwise all the above is good advice.e
mjcapri
Post by mjcapri » Sun Jun 28, 2020 8:23 pm
Yeah forget painting the exhaust manifolds, it’s ceramic coating or nothing!
Post by Mr B » Sun Jun 28, 2020 11:37 pm
I'm not to worried about the exhaust manifolds, I'm just concentrating on the block and cylinder heads at the moment, I literally can't wait to get the engine installed in the car - it's car clinic 3.4 stroker engine and I'm itching to try her out!
