corplugs
corplugs
2.9 efi rear head corplug dose anyone know what size it is please as far as i know all the cologne engines have the same ones any help please thanks in advarnse
Re: corplugs
Hi Chris,
As you can imagine it's difficult to measure them accurately with the engine in-situ.
I've just tried on a 2.3 Cologne motor and it's almost impossible unless certain parts are removed.
I have however, been on an Internet website of a Ford specialist in Germany and it seems there are two sizes for the cylinder head.
One is listed as, 38.2mm and the other is 39.9mm - for all Cologne motors from, 2.0 to 2.8i.
Could it be that the rear core plug is smaller than the front one?
Hope this helps.
All the best.
Hope this helps.
All the best.
Re: corplugs
Curiously though, they also list a full set of core plugs that consists of 11x 38.2mm (plus the 51mm plug), there is no mention of the set having any 39.9mm plugs.
The exploded diagram of a 2.9 cylinder head on Fordopedia also lists the core plugs as being 2 different sizes.
http://www.fordopedia.org/parts-catalog/24-29-v6/B2.10
Re: corplugs
Hi Andrew.
If you go on this website https://www.motomobil.com/online-katalog,4135.html and then click through to page 104 you should see a diagram of a cylinder head where item 18 indicates the front core plug.
When you click on this you are transferred to an item list of which the first three are sets for the motor block.
The last two on the list are for the cylinder head (Zylinderkopf) and they show two different sizes for all heads for Capris from 04/69 – 02/87 and for all V6 engines from 2.0 to 2.8.
I presume the forward core plug has the large diameter.
I tried to measure both on our V6 but it’s difficult. Nevertheless, I had the impression that the forward one is larger.
That's why I went on this website.
Regards
Steve
Regards
Steve
Re: corplugs
thanks to you that replyed
Re: corplugs
still having problams its a 36 mm plug i need ive got 2 sets tthat are ment to be the right ones and a cupale of singale ones with no joy hopefully this bloke recons he has the right one if not ill scrap it and put a 302 musy lump in it? thanks for your help
Re: corplugs
If its a 2.9 it could be worth asking on a Scorpio forum
