Accelerator Pedal Play
Post by pbar » Wed Jun 17, 2020 5:02 pm
Just wondering how much, if any, play you guys have at the accelerator pedal. Just noticed today that I have around half an inch or so of slack 'play' before the pedal has an affect and the revs will rise, not sure if this is normal or not and if I should look at taking this out.
Thanks.
Re: Accelerator Pedal Play
Post by Jasonmarie » Wed Jun 17, 2020 7:03 pm
With out going out and starting the car I agree there is slack as I did notice that on my old car . Next time I am out I will give it ago or when there is a nice day again .
Post by Mr B » Wed Jun 17, 2020 10:34 pm
Hi mate,
I personally wouldn't worry about having a bit of slack as long as the carb/throttle body linkage is fully open when the throttle pedal is hard to the floor.
Post by Bug » Thu Jun 18, 2020 7:47 am
Thanks.
On the carb models, the slack is very often due to the plastic guide where the rod pivots in the bracket on the inlet manifold.
The guide falls out and the first part of the throttle movement is you lifting the rod up until it impinges on the bracket.
You need to push it back in place, but may find it needs a bit of superglue to hold it there.
Other than that you should have no play in the pedal, as far as I recall.
Post by pbar » Fri Jun 19, 2020 5:36 pm
Thanks for the replies guys :)
Spot on, it was exactly that, thank you Martin. With the bush/guide put back in place the pedal was instantly better.
With the pedal wedged down there was still a small amount of extra play at the carb end so tightened the adjuster nut a little to take that play out, so am satisfied it is correct now. (Thanks also to Stevemarl)
Just need to find a way to hold that bush in place as I can tell it is wanting to escape again.
Thank you again Martin.
Post by Caprigear » Fri Jun 19, 2020 7:01 pm
A dab of superglue or a cable tie are usually the methods used.
Post by pbar » Fri Jun 19, 2020 7:52 pm
I was thinking of a cable tie on the spindle butted against the bush. Superb, thanks Martin.
Post by Mc Tool » Fri Jun 19, 2020 9:42 pm
What about these boys? Almost made for the job ( get a few as you wont get the bastards off in one piece )
Post by stevemarl » Fri Jun 19, 2020 11:26 pm
Never mind that, when you can get NOS ones on ebay fo a bargain price :roll:
https://www.ebay.co.uk/itm/FORD-ESCORT- ... SwROtesaCY
(They`ve actually sold one too.)
Post by pbar » Sat Jun 20, 2020 12:11 pm
Starlock washers, never thought of those, yes great idea, that would work a treat.
Post by pbar » Sat Jun 20, 2020 7:45 pm
Burton Power sell the bushes too, so it's good to know that they are available -
https://www.burtonpower.com/weber-throt ... bdgv2.html
Post by Bug » Mon Jun 22, 2020 11:18 am
Excellent. A nice easy fix and proved to myself that my memory hasn't completely gone yet :lol:
Post by pbar » Sat Jun 27, 2020 5:09 pm
And one of the reasons that I, and many others, are glad to see you back here :)
