Tapping noise
- Car(s): Capri mk3 1600 laser,jaguar c.f., daily,Morris minor rarely, mini cooper.
Tapping noise
Hi all
When starting from cold I get a slight tapping noise from the top end and then goes straight off within seconds once oil pressure gauge moves. Is this something to be concerned about or am I worrying over nothing?
Cheers Allan.
Cheers Allan.
Re: Tapping noise
If the engine is tapping my first guess would be cam follower clearances, but if it disappears after getting warm I've no idea if that could be the problem or not...
Re: Tapping noise
Yep, that`s what will be causing the noise - but why, will be due to oil not getting there quickly enough: worn oil pump, general wear in bearings etc, giving low pressure so oil`s not getting to the top of the engine quickly enough. TBH if the gaps were just wrong it`d do it all the time, the clue is that it lasts a couple of seconds then goes.
If the oil`s old & thick, it may help to change/flush oil and replace with the grade recommended by Ford...
Re: Tapping noise
Would the type of oil filter have any effect.
Re: Tapping noise
I've read that Fram oil filters have a bad reputation, I always use Motorcraft oil filters, I believe the correct oil filter for your engine is the EFL90
Re: Tapping noise
I don`t think so, unless it`s clogged? Do you mean make? It`s important that it has a non-return valve so the oil can`t drain back out, (such as the Motorcraft one MrB suggested) Otherwise the filter has to refill before oil can begin to circulate.
Re: Tapping noise
Yes sorry I meant make,car has only done 53,000 miles so hopefully not wear.can get oil light to go out by turning it over for a bit before starting it and then there is no noise.
Cheers.
Cheers.
Re: Tapping noise
Bit confused, do you have both an oil pressure gauge and an oil pressure warning light?
Re: Tapping noise
I've seen oil pressure gauges fitted to car's that came with just an oil light from factory but can't say I've seen an oil pressure warning light fitted to a car that already has an oil pressure gauge
Still confused
Re: Tapping noise
Yes it's a laser with just a gauge, should have said when oil pressure starts to go up after a couple of cranks.
Re: Tapping noise
I'm going with Steve on this, give her a good oil and filter change, Motorcraft oil filter and decent oil - Valvoline oil has a very good reputation, personally used Valvoline for over 20 year's now, it's good stuff.
Re: Tapping noise
That sounds like all`s well with the pressure then, maybe it IS just that the cam followers are a bit too loose. Might be an idea to leave overnight then take the rocker cover off and crank it over to see how long it takes for oil to come out of cam lube pipe, (and that it`s coming out of all the holes)?
Re: Tapping noise
Going to try new filter and oil,
Thanks for the replies.
Re: Tapping noise
You're welcome mate, good luck
Let's us know how you get on
Re: Tapping noise
Will do.
Thanks.
Thanks.
Re: Tapping noise
If you're going to change the filter and oil it would probably be worth checking/changing the oil spray as well?
Cheap part to buy new, or alternatively I cleaned mine in petrol and blew it through with an air compressor to make sure it was clear - if you're checking/changing the oil and oil filter, might as well make sure it's getting to the the top of the engine in the first place...?
Re: Tapping noise
D366Y wrote: ↑Sun May 31, 2020 10:45 pm If you're going to change the filter and oil it would probably be worth checking/changing the oil spray as well?
Exactly what I was going to say too.
If that spray bar is starting to clog up the oil will take a while to get to the front and back. The oil comes up the middle and then goes to both ends, spraying out small holes onto the cam lobes as it goes. That's why it's always the extreme end followers that tend to wear quickest.
Blowing it through is a fix yes, but I'd be wary of whether it was all done completely. If the end hole isn't right at the end of the tube then some crud will end up forced into the end, just waiting to wreak havoc again.
I'm sure you can still get the spray bars relatively cheaply? Try Burton Power.
Make sure you put a rag across all the holes in the top of the head before you unbolt the spray bar.
One of those bolts disappearing into the bowels will give you a bigger tapping noise to worry about!!
Re: Tapping noise
£25 from Burton Power
Bit cheaper here https://www.tjmotorsport.co.uk/proddetail.php?prod=sbar
Re: Tapping noise
Jeez! I bought ten of them for less than that................................ok so that was about 25 years agoD366Y wrote: ↑Mon Jun 01, 2020 9:38 am £25 from Burton Power
