Fuse Box question
Owent2005
Fuse Box question
Post by Owent2005 »
Happy Bank Holiday!
I am cleaning up my fuse holder and have found that I only have continuity between the fuse holder and tab at fuse 3, 4 & 6. Is this right or do I need to strip it further?
TIA
Owen
Re: Fuse Box question
Post by stevemarl »
Just looking at it, it ~LOOKS as if the blade connectors are riveted to the fuse clip? I can`t work out from Haynes - it seems the reverse light is fed by 4 fuses at once! :roll: :roll: I`ll check later, but my guess is that they should connect, maybe just badly oxidised at rivet?
Post by stevemarl »
I`ve tested mine and they all seem to have continuity. You may need to drill out rivets, clean up, and either use a new rivet or a very small nut/bolt, 2mm D or so. Or clean up rivet heads and solder them maybe?
Owent2005
Post by Owent2005 »
Thanks for checking Steve, while tracing one issue I seem to keep coming across others, I’m sure I’ll get there in the end!
Owen
Owent2005 wrote: Mon May 25, 2020 8:53 pm while tracing one issue I seem to keep coming across others, I’m sure I’ll get there in the end!
Owen
Welcome to capri ownership!! :lol:
Owent2005
Post by Owent2005 »
Quick update,
I wasn't keen on drilling out the rivets so i thought i'd put a blob of solder between the tabs and the fuse holder. The solder didn't want to take so for now I have added a wire from the fuse holder (through the hole below where the fuse sits) and connected the accessory to the wire. It is only fuse 1 that didn't have continuity that had an accessory coming off the tab. This will do for now but will look at doing something more permanent later.
Thanks for the suggestions, Owen.
Post by Caprigear »
I have good fuse boxes in stock.
Owent2005
Post by Owent2005 »
Caprigear wrote: Wed May 27, 2020 9:04 pm I have good fuse boxes in stock.
Thanks, how much are they I can’t find them on your site?
Owen
Bod9084
A 1987 2.8i thay are both red
Post by Bod9084 »
I have a spear cues box if you end one
Owent2005
Post by Owent2005 »
Bod9084 wrote: Thu May 28, 2020 7:39 pm I have a spear cues box if you end one
It would be good to get a fully working one, how much would you part with it for?
Post by Not_Anumber »
I tried the same thing with soldering the rivets with the same result. It might be feasible with a stronger soldering iron but a 15 watt / 25 watt general purpose soldering iron just wont do it due to the amount of metal that needs heating up.
After a couple of attempts I got a good second hand one from Caprigear, fully reliable now.
Bod9084
Post by Bod9084 »
Sorry not got back but send me a photo of the bottom
the opposite side to where the fuses go as some have different links
And I’ll match it up my email
Address is
[email protected]
