Indicator/horn stork no longer working
Owent2005
Post by Owent2005 » Tue May 12, 2020 2:52 pm
Afternoon, hope everyone is well
My indicators and horn have stopped working (along with the rev counter). The horn wire has continuity from the stork to where it connects to the horn but no voltage when operated. I’m guessing that power isn’t getting to the stork (if that’s a thing)? I’m in the process of tracing all the wiring but it’s a bit of a mess.
Does anyone have any pointers or come across this before?
TIA,
Owen
Re: Indicator/horn stork no longer working
Post by D366Y » Tue May 12, 2020 4:15 pm
I think this is a relatively common issue caused by the stalk just being broken... I had a similar issue before and replaced the stalk and it solved the problem but I knew before that the wiring worked before.
I think it has something to do with the metal casing around the bottom of the stalk cracking which causes the issue?
Owent2005
Post by Owent2005 » Thu May 14, 2020 8:16 am
Cheers Danny,
Ive managed to get the horn working after basically stripping cleaning and rebuilding all the parts. The main beam also works from the stalk so I'm suspecting a nipped earth or dodgy connection somewhere. I start on the indicators today so fingers crossed.
Im not sure if its connected, but my rev counter, fuel gauge and eng temp aren't working, I'm wondering if theres a common earth that might be dodgy? I have the Haynes manual but the schematics aren't great!
Owen
Post by Bug » Thu May 14, 2020 9:01 am
Cheers Danny,
Owen
Have you been up behind the instrument cluster?
That sounds as though it could be something as simple as the multiplug being slightly disturbed?
Owent2005
Post by Owent2005 » Thu May 14, 2020 5:15 pm
Is the multi plug the Flasher Unit? And is this the flasher unit in the picture? I traced the wires to it and was going to ask how I can check that it’s serviceable.
Owen
Post by Andrew 2.8i » Fri May 15, 2020 7:15 am
Hi Owen,
The multiplug that Bug is referring to is the one that plugs into the back of the instrument binnacle.
As I'm sure you know, the flasher unit is simply a 3 pin relay and a replacement is freely available.
Alternatively, there is this modern replacement:
https://www.ebay.co.uk/itm/3-Pin-Upgrad ... Sw1EJc7FY3
You should be able to test your existing unit to see if it works properly.
Post by stevemarl » Fri May 15, 2020 11:43 am
Just for absolute clarity, the flasher is not a simple relay as such, it does contain the circuit which causes flashing (via an onboard relay). Just in case the OP tried to test by substituting a conventional SPST relay?
If anyone`s interested?
Owent2005
Post by Owent2005 » Fri May 15, 2020 11:55 am
Thanks guys,
Ive tested the relay (which looks like the one in your picture steve) and when i put power to it, the relay, I think, is staying on as the test light stays on, (Im not sure if its going really quickly due to there being no resistance to the circuit) and the relay makes a constant tone.
With power connected should the relay be clicking on and off?
Thanks,
Owen
Post by stevemarl » Fri May 15, 2020 12:03 pm
Owen,
I can`t remember, but AFAIK although electronic it still flashes quicker if a bulb blows (I think deliberate design) which means if you`re testing it without a load it may just stay on, or just oscillate - the buzzing from the relay? I can botch together a circuit later this afternoon to see how it works with/without load.
Owent2005
Post by Owent2005 » Fri May 15, 2020 12:06 pm
Owen,
That would be great if you could Steve thanks
Post by Bug » Fri May 15, 2020 1:16 pm
Hi Owen,
Sorry, yes. To clarify, I was addressing your issue with the possible common earth fault on your gauges.
Post by stevemarl » Fri May 15, 2020 5:52 pm
Turns out you`re very nearly spot on, except no current rather than no resistance. I`ve run one this afto and with a 21w bulb it flashes fairly rapidly: with the correct load (2x 21w) it flashes normally. witha a 5w bulb it flashes so fast the relay is just vibrating (buzzing!) so fast the light appears constant. There`s a very low value resistor in series and the voltage drop across this triggers the switching, presumably to retain the change in speed to warn you of bulb failure even though it`s now an electronic device not bi-metallic strip. Circuit to test is:
Owent2005
Post by Owent2005 » Fri May 15, 2020 7:08 pm
That’s great Steve thanks. I was thinking the relay was fine and your test confirms this.
As you’ve seen from my other posts I’ve a few gremlins to get through. Could the issue of the indicators/hazards not working have anything to do with the lack of gauges working on the instrument panel as according to Haynes one the wires goes to the indicator flasher. Or could it be to do with the system not charging properly?
Thanks,
Owen
Post by stevemarl » Fri May 15, 2020 7:32 pm
I think it`s more likely to be the multiplug on the instrument cluster as others have suggested, as the whole of the cluster is powered and earthed through this one plug. Probably just needs to be unplugged, spray of switch cleaner, or wd40, and pushhed in & out a couple of times. (the wire you`re talking about is probably just going IN to the green turn warning light?)
Owent2005
Post by Owent2005 » Fri May 15, 2020 8:38 pm
Ok thanks, the instrument panel is hopefully coming out tomorrow so I’ll let you know how I get on.
I guess I’ll keep tracing wires to get to the bottom of the hazards/indicators!
