Bushes
03kkeane
Car(s): Ford capri mk3 2.0s
Bushes
Post by 03kkeane » Mon May 04, 2020 4:34 pm
Hi I’m re bushing my mk3 Capri 2.0s can anyone tell me what size is the anti roll bar front and rear . Please on the website it says standard front are 24mm and rear 12mm is this correct
Re: Bushes
Post by Not_Anumber » Wed May 06, 2020 11:41 am
It may depend on the year. Its best to speak to Martin, he found the right size ARB bushes for me. Go for Superflex poly bushes if you can, they dont cost a lot more than the basic rubber ones, are stronger as well as far less of a struggle to fit.
Just a thought, check the actual diameter of the ARBs on yours too as its always possible a previous owner could have uprated them at some point as they are relatively easy to swap.
Re: Bushes
Post by Caprigear » Wed May 06, 2020 12:10 pm
I have the full range of superflex bushes. Some 2.0 had 22mm but others were 24mm. Original rear ARB were 12mm but could possibly have been upgraded to a 14mm one from a 2,8i.
All I would need is the diameters of the bars I and I could supply the correct bushes.
