I noticed a small leak from the carb body onto the manifold. After removing the carb body there is a paper gasket, a thicker bit of plastic and a thinner bit of plastic (not sure what they are called).
I can see the rebuild kit has the paper gasket which is great but the thinner plastic part is broken on one side. Any idea where I can get one from or what my options are?
Carb Gasket
- SpaceHopper
- Car(s): Ford Capri 1982 2.0 (65km only)
- SpaceHopper
Re: Carb Gasket
Scratch that, I found a mounting spacer gasket that will do the job.
