Respray finished, she is out of isolation.
I'm trying out some chrome Cyclones, what do you think, do they suit the MK3?
The Cyclones have a 75mm centre bore though, isn't the Capri 63.4mm?
Cyclones
Re: Cyclones
Cor them dualies on the rear end are fackin dank.</aus>
Re: Cyclones
I think they look sweet mate, if you're concerned about the center bores there are kits on eBay that can sort that out - sort of tapered rings that fit over the hub to take up the difference in circumference.
Re: Cyclones
Am I right in thinking that the two on the other side of the car will rotate the opposite way and therefore should be called hurricanes???
Re: Cyclones
Is there a way to bring Tornado back??
