Oily Sparks
Re: Oily Sparks
Fair play to Burtons - even with everything happening they've still managed to get my order here in 48 hours!
Not had a chance to get a shiny new rocker cover yet so will have to stick with the one I have for now and give it a good look over and check it's all in good shape before I go putting it back on again.
Cheers!
Re: Oily Sparks
D366Y wrote: Fri Apr 03, 2020 2:40 pm Fair play to Burtons - even with everything happening they've still managed to get my order here in 48 hours!
Well, the roads are empty :xd:
Re: Oily Sparks
Haha true!
I've decided to start throwing money at this by the looks of it...
My hoses don't match and it's annoying me :lol:
I purchased a load of Samco hoses before but I think I got the wrong set as there was one or two that I couldn't figure out where to put and guessed I'd got a set for an auto choke rather than manual choke but looking again (3years later :doh: ) I think it it may be something else...
Naturally I was drawn to this link
https://www.ebay.co.uk/itm/Ford-Capri-1 ... IkCdCQ56qw
But in retrospect as my car was originally fitted with a VV carb should I be buying this set instead?
https://www.ebay.co.uk/itm/Capri-1-6-2- ... SwV0RXttDO
Bit of a loss really... the first one doesn't have the correct pipe to go over the top of my rocker cover into the carb by the VV one does, but then I'm not sure how it goes into the carb when at the moment I have the original black hose over the top of the rocker cover, into an elbow joint and then got a hose going round the side into the carb manifold...??
Re: Oily Sparks
Changed my mind - have decided to give up instead
Spent the whole day yesterday stripping back the engine and took the manifold and loosened off the carb manifold so I could move it back and give myself some space to do the followers.
Then changed all the followers with new springs and checked my spray bar which was OK but I cleaned it up again and ran some compressed air through it so I know it's all cleared out.
Put everything back together again after 9 hours of tinkering and it barely turns, and makes some horrible noises when I try and turn it over.
I've accepted defeat and will tow it to a garage and they can deal with it instead
