Battery Clamp Bolt
Battery Clamp Bolt
Post by pbar » Wed Mar 18, 2020 9:52 am
Anyone know what size/thread the battery clamp bolt is please, the one which bolts into the battery tray captive nut.
Re: Battery Clamp Bolt
Post by stevemarl » Wed Mar 18, 2020 10:19 am
Paul,
it should be just an M8. (Going off the 13mm head) I can check thread later?
Edit: it is just a standard M8 bolt, coarse (1.25mm pitch), 30mm long. If you want I can send you one this afto?
Post by pbar » Wed Mar 18, 2020 10:44 am
Thanks for response Steve. I have tried a couple of standard bolts which I have but nothing seemed 'right' so was just going to pop to the hardware shop if I could ascertain what it should be to see if they had any.
Edit: just seen your edit :) If you are sure you don't mind Steve that would be magic, thanks! No rush.
Post by stevemarl » Wed Mar 18, 2020 10:54 am
Yep, I`ll get that off now. (It could be that the captive nut has been corroded or cross-threaded in the past, in which case it may need `chasing` with a tap? I`ll lend you a tap in case, should be able to grip with pliers, if it`s too tricky, a holder will only be a couple of quid on ebay. )
Post by pbar » Wed Mar 18, 2020 11:04 am
I do have a tap & die set so I should be ok with that, but thanks Steve. Yes I did think it may be gunked up, will see when I try the proper size bolt now :)
Post by stevemarl » Wed Mar 18, 2020 11:15 am
Preparedness - this is what we like to see!!! OK, shouod be there tomorrow.
Post by pbar » Wed Mar 18, 2020 11:23 am
Thanks again! :) Messing with cars is one of the things keeping me sane with what's happening.
Post by stevemarl » Wed Mar 18, 2020 11:39 am
Yep, I`m with you there!!!
Post by Paul G » Wed Mar 18, 2020 11:42 am
When you finally fit the new bolt run a bit of Copperslip around the threads to stop it rusting up again when you go to remove it.
Post by pbar » Wed Mar 18, 2020 11:46 am
Thank you Paul, good advice as always. Actually I am fitting a little something else to one of the spare holes, but yes copper grease is great advice, do that a lot.
Post by Jasonmarie » Wed Mar 18, 2020 1:33 pm
What a nice result glad it’s sorted also like the tip on the copper grease never thought of that
Post by pbar » Fri Mar 20, 2020 7:19 am
Thank you Steve, arrived yesterday, spot on as always. Look forward to seeing you again soon, if we can find anywhere open, and safe!
Post by stevemarl » Fri Mar 20, 2020 10:45 am
That`s good! I was thinking maybe Marple, Sunday, as could be last chance before it really sets in? I`ll mail later. (always assuming it`s even open?)
