Crank case breather valve
Rosetti
Car(s): Ford Capri laser 2.0
Post by Rosetti » Fri Feb 28, 2020 3:58 pm
I think that's what it's called. Tube from the crank case to a 4 inch cylinder attached to inside of wing. Been giving me ignition probs.so I'm guessing it's a valve. Any clues for a new/2nd hand one? [email protected]
Re: Crank case breather valve
Post by Not_Anumber » Fri Feb 28, 2020 5:20 pm
It sounds like someone has added an aftermarket catch tank. Can you post some photos ?
Also can you describe how it is interfering with the ignition Is the vacuum advance to the distributor fed from this rather than from the carb/ inlet manifold ?
Post by pbar » Fri Feb 28, 2020 5:22 pm
The standard crankcase breather on the Laser looks like this on the engine block -
Post by Not_Anumber » Tue Mar 03, 2020 9:55 pm
is that a 205 block i just spotted ? Best of the bunch they were
Post by Mc Tool » Wed Mar 04, 2020 4:53 am
:roll: why do you think he took the pic from that angle :D
Post by pbar » Wed Mar 04, 2020 7:09 am
That is a 205 block yes, although it is a pic off the internet, not mine.
Post by Mc Tool » Wed Mar 04, 2020 8:38 am
Well, I was thinking it was looking a bit unloved, which surprised me a bit , :) pleased to hear its not yours :)
Post by Paul G » Wed Mar 04, 2020 4:29 pm
The crankcase breather / PCV valve should not have a pipe going to a remote pot but should be connected to the inlet manifold to allow the engine to burn the excess crankcase gasses.
The breather system shouldn't have any effect on your timing.
Post by Mc Tool » Wed Mar 04, 2020 5:49 pm
Op said about a tube going to a cylinder on inner wing ......could be a ht lead going to the coil ......"been giving me ignition problems" .....yes ? ....no? :?
Post by Major_Tom » Thu Mar 05, 2020 5:20 pm
He did say it was a tube from crankcase to cylinder on wing though. But youre right, 4in cylinder on wing + ignition problems + no photos × no replies = more info required.
My car isn't stupid.... it's MENTAL.
Post by Not_Anumber » Thu Mar 05, 2020 10:11 pm
I fear we may never hear the full saga unfold as Mr Rossetti seems determined to be a 1 post wonder.
Asks a question but doesnt want to hang around the forum for long enough to hear any answers. :banghead:
Post by Major_Tom » Thu Mar 05, 2020 11:00 pm
Coronovirus has got him :lol:
