Electrics and wiring
mwillerton
Car(s): Ford Capri 2.8i special - Diamond White
Honda Civic 2.2d.
Yamaha Fazer 600
Post by mwillerton » Sat Feb 08, 2020 5:38 pm
Does anyone know what this connector is called and are they available new? They look like tow bar connectors... I wonder if they are the same? Image
Thank you in advance
Re: Electrics and wiring
Post by Caprigear » Sat Feb 08, 2020 6:00 pm
I've never seen them available, only on wiring looms.
Post by Mc Tool » Sun Feb 09, 2020 5:33 am
They are a moulded on plug and thusly cant be replaced as such, you could just chop them off and fit another plug assy but nothing on the planet would be as good in that particular situation, so they are worth a bit of effort to recondition . I rolled up small bits of 600 wet n dry sandpaper and sanded all the pins and sockets , reshaped sockets . Some times all thats needed is to squirt a bit of wd40 on it and plug it in and out a few times to scrape the crud off the terminals then a blast of air to blow that shit off and a fresh squirt of wd40 and stick them together .
STEVEW
Car(s): Ford Capri 2.3S
Project
Post by STEVEW » Sun Feb 09, 2020 8:29 am
Hi McTool
mwillerton
Honda Civic 2.2d.
Yamaha Fazer 600
Post by mwillerton » Sun Feb 09, 2020 9:11 am
Thanks for the advice. I am trying to make a new loom.
I am thinking to remove all the old cabling, replacing with new and applying a sealant and rubber to cover?
mwillerton
Honda Civic 2.2d.
Yamaha Fazer 600
Post by mwillerton » Sun Feb 09, 2020 9:12 am
Or chop off and solder new to old
Post by Bug » Sun Feb 09, 2020 10:38 am
I guess it depends how original you want to be.
I always used to use:
www.vehiclewiringproducts.co.uk
They seem to stock everything and may well have some new weatherproof alternatives.
Worth a look?
mwillerton
Honda Civic 2.2d.
Yamaha Fazer 600
Post by mwillerton » Mon Feb 10, 2020 7:00 pm
Thanks, I will take a look
