Fixings for standard 2.0 pinto air filter housing
Post by Brooksy » Thu Jan 30, 2020 4:57 pm
Hi All
Does anyone know where I can get or even have, the 4 x 10ml head size screws that secure the 2 support brackets, to the factory 2.0 pinto air filter housing to rocker cover? (Martin has found me the 2 brackets).
Also, are there specific plastic female connections that the screws go into? (On the side of the rocker cover) If so, I'll need these two, or a suitable alternative.
Currently, mine has different plastic clips that secure the HT leads, which don't look suitable for reinstating the factory setup.
Thanks.
Re: Fixings for standard 2.0 pinto air filter housing
Post by Jasonmarie » Thu Jan 30, 2020 5:29 pm
I bet I will find them brackets now but glad you sorted some from Martin the same bolts that go in to the filter go in the bottam . Here’s a Old picture of mine I just found . Hope this helps I did get a my bolts From John Hill @ Capri club international, I just asked and he sent me two for £3 I think a few years ago as I lost one .
Post by Brooksy » Thu Jan 30, 2020 6:11 pm
:cool: Thanks for the info and photo Jason.
Post by Brooksy » Mon Feb 03, 2020 3:17 pm
Just in case anyone does have 4 of these (for 2.0 air filter housing bracket/supports) Size = 10ml head x approx 2cm in length. Obviously, I'm willing to pay and for P&P.
Have tried Martin, CCI, Colin etc.
Thanks.
Post by Caprigear » Mon Feb 03, 2020 7:37 pm
They're similar to the ones that fix the radiator and the radiator cowling, thinking about it I probably have some.
Post by Brooksy » Tue Feb 04, 2020 12:20 am
Great Martin, let me know if you do. Thanks.
STEVEW
Car(s): Ford Capri 2.3S
Project
Post by STEVEW » Tue Feb 04, 2020 9:33 am
Hello Brooksy
As there has been no follow up to your initial post about your needing the pictured bolts I take it you still require them.
I have a similar self-tapping screw: 10 mm head / 20 mm thread length / 6 mm thread dia plus six with a thread length of 17 mm.
I know these may not help you however, I can maybe steer you in the right direction.
I obtained these screw from that well-known purveyors of equipment to discerning car owners: Hörmann.
Never heard of them? Not surprising: they're a German company which manufactures garage doors and it's how I got these screws.
They're used to hold the aluminium sections together.
They have a serrated washer; contain a bi-hex Allen key form in the head and are galvanised.
So if you are still having a problem get down to your local DIY shop or wherever else they supply/manufacture garage doors etc.
The purists may frown but who cares?
If you still need some let me know and I'm sure I can get you some.
PS:
Our 2.3S now has a, "Hybrid Cool Air Induction System".
Why hybrid?
It's built up from components manufactured by Ford and Marley. The latter obtained in the sanitary department of our local DIY centre.
"Washing, polishing and displaying cars is fine however, I much prefer driving mine. :lowrider:
Post by Caprigear » Tue Feb 04, 2020 4:55 pm
The fittings you need are M6 x 15 for the bottom of the bracket into the side of the rocker cover. The top bolts are the same as is used in mounting the radiator and the plastic cowl.
I can't figure out how to put pictures up.
Post by stevemarl » Tue Feb 04, 2020 5:14 pm
Martin, upload here then link: https://postimages.org/
Nige, M6 bolts are available anywhere: £1.29 for 10 The others from Martin.
https://www.ebay.co.uk/itm/HEX-HEAD-SET ... 7822304eeb
Post by Brooksy » Tue Feb 04, 2020 6:36 pm
Thanks Stevem, Stevew and Martin for the information and noted.
:cool:
Post by pbar » Wed Feb 05, 2020 7:34 am
I wrote this ages ago but I think it still applies -
2. Click Choose Images
