Capri mk1 headlight relay same as cortina?
CapriCrayford3000
Car(s): Capri Crayford 3000 GT XLR
Post by CapriCrayford3000 » Mon Jan 06, 2020 12:57 pm
Hiya, does anyone know if the headlight relay 4 fuse version, from a cortina mk3 with twin headlamps ie as per mk1 facelift capris, would work with mk1 facelift capri? I believe the headlamps are identical ....
Re: Capri mk1 headlight relay same as cortina?
Post by Mc Tool » Wed Jan 08, 2020 3:25 am
I would say so , if it ain't perfect fit it would be adaptable. You could always get 2 new 20amp fused relays and fit them up ( one for low beam and other for high ) . All the wiring should be there , maybe need to change a terminal or two. Relays are like tires .....heaps of people make them and you can choose between a few options.
