Hello all,since I'm used to cars with auto choke,so I'm not too sure what the manual choke operates. The only function I can see,is that it shuts the choke valve,to enrichen the mixture,by reducing the air volume. Does it also control additional fuel supply?
thanks
Paul
Weber ICH manual choke operation?
Re: Weber ICH manual choke operation?
It is exactly as you describe, less air to the mixture when closed. Slowly opening up to allow more air in as the car warms, until no choke is needed.
- Car(s): Ford Capri Cabaret 1.6,Ford Cortina MK5,1992 Ford Sierra Coupe,1988 Ford Sierra Coupe.Ford Sierra XR4i
Thanks pbar. I know the dgav when throttle is pressed from cold, the valves shut and squirts a bit of fuel. On my Capri being with an ICH carb, with the choke out from cold start, it cuts out.
The squirt of fuel is just the accelerator pump, this squirts every time the throttle is opened. If your ICH is not doing this it could explain why mixture is weak and cutting out. If you look down the choke and move the throttle, can you not see (and hear) a squirt?
