Rear Creaking & big knocking over bumps
80s-new-man
Post by 80s-new-man » Sat Oct 19, 2019 6:08 pm
Hi , this has got worse over the last couple of months, it seems there is a creaking sound and quite abrupt “hits” when I go over even small bumps. It feels like the car is hitting bump stops or something.
Could it be very worn out shocks/dampers?
Cossie 24v BOB heart transplant
Allan mcl
Re: Rear Creaking & big knocking over bumps
Post by Allan mcl » Sat Oct 19, 2019 8:06 pm
Have you checked the rear leaf spring shackle bushes for wear, if the ride height is ok it be those or they could be loose.good luck.
Post by Mc Tool » Sun Oct 20, 2019 4:50 am
Yep , :agree: , sounds like a rubber bush has given up ,possibly a shock mount . Shouldn't be to hard to see, there ain't any hidden bits on Capri back end :D
80s-new-man
Post by 80s-new-man » Sun Oct 20, 2019 6:56 am
Ah I see, thanks for those pointers guys, I’ll try and have a look in those areas 8-)
Post by Paul G » Mon Oct 21, 2019 10:30 am
If the shackles are OK, I'd jack the rear up with the axle hanging and check the springs themselves for any fractures etc. Also give them a good wire brushing and possibly a coat of WD40 just to eliminate "stiction" ie friction causing the leaves to stick to each other when they should be able move as the car goes over bumps etc. This is quite a common cause of creaking with multi-leaf springs.
Post by D366Y » Mon Oct 21, 2019 10:38 am
Spooky, I've just noticed the same issue over the weekend as well - will check the bushes :)
