Strut rebuild , roller top mounts or standard ?
Posted: Sat Sep 28, 2019 6:52 pm
by caprikid61
Hi Folks, that's the capri parked up for the Winter so I can start to catch up with the work needing done to keep her in tip top condition. I have noticed that she is lying pretty low at the front and I have a steering wheel shake when turning right.
I have decided it is time to give the struts a good overhaul by replacing the shocks, springs, tca's and track rod ends as well as the top mounts . Any help or advice would be great but my first question is are roller top mounts worth all the extra expense? As I don't have power steering I thought they might make my steering lighter ? Has any of you folks tried them ? Cheers Alex
Re: Strut rebuild , roller top mounts or standard ?
Posted: Sun Sep 29, 2019 4:10 am
by Mc Tool
They will lighten the steering a bit . I got top mounts with a bearing mounted in rubber so you get the benefit of a bearing without the harshness of a solid mount ( got em off Burton's ), I can't get past the fact that when steering the springs get wound up one way and down the other
also got the bushed adjustable TCA's, and now that I have figured out how the tension or compression struts work ....get me some of that too.....and the link kit to keep the ARB.
Posted: Mon Sep 30, 2019 1:23 pm
by caprikid61
My springs do the same when I turn the steering they also move and they also make a clunking noise . Good shout about the roller strut top bearings being to harsh
I had never thought of that , so I will be getting mine from Burton.
Posted: Mon Sep 30, 2019 9:00 pm
by Mc Tool
The mounts I got are mp167
And the bush kit is mp180
Hot tip, when Burton's refer to large hole and small hole top mounts they are refering to the size of the hole in the inner guard under the bonnet that the mount bolts into ....not the size of the hole in the bearing that the strut fits thru . There are 1/2" and 5/8 struts but I think only the 5/8 applies to Capri ,1/2" is for early drum braked escorts.
Posted: Mon Sep 30, 2019 9:36 pm
by stevemarl
Do the roller mounts affect the ride height?
Posted: Tue Oct 01, 2019 4:12 am
by Mc Tool
Either 1/4" or about 3/4" depending on how you arrange the spacer kit on the strut.
Posted: Tue Oct 01, 2019 6:04 am
by pbar
caprikid61 wrote: ↑Mon Sep 30, 2019 1:23 pm
Mine used to do this. I changed the springs for brand new standard height Kilen ones, and it has been perfect since.
Posted: Tue Oct 01, 2019 11:38 am
by stevemarl
pbar wrote: ↑Tue Oct 01, 2019 6:04 am
Yes, I was going to say the same, it`s usually because the springs are shorter, O.E. ones locate firmly in the cups. Presumably if the roller mount is a little deeper than what you have now, this may compress the spring more and stop the knocking?
Posted: Tue Oct 01, 2019 10:20 pm
by Mc Tool
Can't see how it makes a difference what brand of spring you use they still don't rotate with the strut.Cant be a coincidence that anyone twerking or racing escorts and capris fit roller top mounts fairly early in the evolution of the build . Burton supply Gaz inserts that are made to fit strut assy's with springs that lower the ride height by 2". They limit the extended length .
Posted: Wed Oct 02, 2019 6:04 am
by pbar
Mc Tool wrote: ↑Tue Oct 01, 2019 10:20 pm
I think it's more the fact that old springs are weak, compressed and less efficient. Certainly, changing mine to brand new Kilen ones made a big difference.
Posted: Wed Oct 02, 2019 9:36 am
by stevemarl
"Can't see how it makes a difference what brand of spring you use they still don't rotate with the strut."
No, obviously they still twist, but the O.E. length springs locate securely in the seats (as they are still under compression even when suspension is unloaded) so don`t move / make clunking noises. Shorter ones are on the threshold of compression so CAN move in their seats. That`s what we were saying.
Posted: Wed Oct 02, 2019 9:35 pm
by Mc Tool
