Engine Swap - Pinto 1600 to Pinto 2000
Cosmicbike
Re: Engine Swap - Pinto 1600 to Pinto 2000
Post by Cosmicbike »
340truck wrote: Thu Sep 19, 2019 5:04 pm Two people can easily lift a pinto....rope around it as if you're using a hoist, fence post or similar through the rope and one person either end of the post.
And fit the 2.0...the specs given for the 1600 are accurate with those simple mods....ask Dan about the one I built for him....but as far as you can go with it. Lairy cams are risky, not much valve clearance if you mess about with lift and duration. Whereas the 2...well, no stopping really. Only the depth of your pocket restricts the power available.
We managed it OK in the end. I took the head off and then we just dropped it onto the engine stand. Managed to create space to store it, the car will need to move to enable any work, the joys of a single garage.
Cosmicbike
Can anybody advise a source for a flywheel? I'm not sure what the standard size is, though I think it's 215mm (8.5" in old money)? Not sure if I should go for a 2nd hand cast or fork out for a steel one which all seem to be lightened?
I have an original 2.0L one going spare if you decide to stick with it - not sure of the measurement but I can check when I get back tomorrow evening
Cosmicbike
D366Y wrote: Sun Sep 22, 2019 4:59 pm I have an original 2.0L one going spare if you decide to stick with it - not sure of the measurement but I can check when I get back tomorrow evening
Thanks Danny I'd appreciate that
Cosmicbike
Thanks for the flywheel Danny, now settling in under the rest of the bits waiting for some spare time.
Cosmicbike wrote: Sun Sep 29, 2019 3:06 pm Thanks for the flywheel Danny, now settling in under the rest of the bits waiting for some spare time.
No worries, just make sure you keep us updated with the work over winter! :)
nigecapri
Post by nigecapri »
The 2.0 Weber carb will be o.k. but if you decide you would like more GO then don't bother with twin 40's, just get a set of bike carbs & suitable manifold. Superb modification for a Pinto, rev forever (100 in 3rd) and silky smooth at a very low tick over - Phil from MK CapriCare saw mine & couldn't believe how slow it was ticking over without stalling.
Whats the ecconomy like with bike carbs ? Im thinking about them for a different old car project I have on the go
Cosmicbike
One step at a time, I'll start with the Webber and go from there. I still have a hankering for a V8.....
nigecapri
Post by nigecapri »
The Weber will be fine with a K&N or similar & full flow exhaust on a 4-branch.
Bike carbs are good on fuel *see disclaimer, my 2.0 will do 36.5mpg at a steady 70mph. * disclaimer: WOT with the supercharger on through bike carbs does not offer good fuel economy, it's not supposed to...
Cosmicbike wrote: Thu Oct 10, 2019 9:11 pm . I still have a hankering for a V8.....
I have a rover v8 going in mine , weighs less than the pinto engine , and not so stupidly powerful that I have to worry about the diff /gearbox ect ( probly a lsd ). Happy to share ideas :D
pbar wrote: Thu Sep 19, 2019 11:18 am Messing around with cars gives me aches in muscles which don't even react to a week long workout in a gym!
You cant see the other blokes helping him out, just out of shot to the left, a couple of guys are holding onto that top hose and taking the majority of the weight.
Cosmicbike
Mc Tool wrote: Sat Oct 12, 2019 7:11 am
Funny, I was thinking 3.5 Rover V8, it's light and not too torquey. I'm sure the diff and rear axle would be OK, not sure about the standard gearbox though which started me looking at Tremec T5 and LT boxes. I reckon I should probably get the shell sorted first though!
Toyota w56 w57 5 speeds are cheap enough and bullet proof behind a rv8 , with a land cruiser clutch plate. Googling them will show various internal and overdrive ratios
