Hello,
On the 2.8 I assume the clutch cable routes around to the LHS of the steering coupling as you look from the front of the car?
Should there be a clip that holds the clutch cable to the inner wing, out of harm's way of the exhaust manifold?
If somebody knows the answer to this or can check for me, that would be great!
Thanks,
2.8 Clutch Cable Clip
Re: 2.8 Clutch Cable Clip
I know that we've spoken about this before somewhere but I know Nick has a bit of copper tied into his inner wing to hold his clutch cable back - I think peter has a cable tie or something similar on his as well because we all seem to have a problem with the cable melting on the manifold
Not sure if there was a specific clip for holding the cable in place for any of the models or if we all just find a different way to bodge it
Thanks Danny.
I did a quick search, but could not find a definitive answer about a factory original clip.
Hi Andrew,
Yes there is a clip on the inner wing for the cable
Phill
Phill
Thanks Phill, what does the clip look like?
Sorry for the slow reply, just got back from a car show
I've just had a closer look tonight, I have two white plastic clips.
The top one clips the clutch cable to the brake pipe
and the bottom one clips it straight to the car body.
They both are push fit.
