Front crossmember
Front crossmember
Post by Mr B » Fri Aug 30, 2019 9:13 pm
Evening all,
Just about to paint my front crossmember, obviously needs to be tough paint to with stand the battering it will receive, any suggestions guy's?
Re: Front crossmember
Post by Mc Tool » Fri Aug 30, 2019 9:24 pm
If you want it to stay lookin good I'd go for powder baking , or Hammerite , or that stone chip stuff if you can handle the texture (it ain't smooth )
Post by Mr B » Fri Aug 30, 2019 9:39 pm
Thanks MC, Won't have the time to get it powder coated, but Hammerite looks like a good option, I was thinking of black stone chip protector mainly for how quick it covers, I've wire brushed the crossmember - took ages to get all the shit off it :deadhorse:
ThatGuy
Car(s): 1986 2.0 laser
Post by ThatGuy » Sun Sep 01, 2019 10:27 pm
When I painted mine I dropped it out of the car, cleaned it all up and hammerited the shit out if it.
Although I'd suggest giving it a good few coats as mine has worn away slightly from jacking it up off of it
Ratty as fuck
Post by Not_Anumber » Mon Sep 02, 2019 8:01 pm
I put a few coats of truck bed liner paint on my rear axle and brake drums before fitting . Its not a smooth finish but its definitely very tough and isnt prone to chipping..
Post by Mr B » Mon Sep 02, 2019 11:11 pm
Hi guy's,
Thanks for all the replies, in the end I went with MC's Hammerite suggestion, I had to be quick as the GXL is currently at Tickovers having a power steering conversion done, it's my other halfs car and she has never been able to drive her since buying her in 2009 simply because the steering is too heavy.
Post by Not_Anumber » Tue Sep 03, 2019 3:10 pm
Thats interesting, what type of power steering conversion do Tickover use and whats the approx cost if you dont mind me asking ?
Post by Mr B » Tue Sep 03, 2019 10:17 pm
Hi mate,
The conversion is reasonably easy to do, I supplied Ticks with all the necessary part's, the parts came from a Capri MK 2 3 litre Ghia, the parts I supplied were the power steering rack, crossmember, engine mounts, associated piping, pump, pulleys and ATF reservoir, the cost is a bit hard to estimate as the car was having exhaust work done as well but I reckon a couple of hours labour to do the job as long as you are supplying the parts for the conversion which works out to around £140 as long as all the old part's come off the car without a major struggle, power steering makes a spectacular difference to the car - for example a 3 point would be nigh on impossible for my partner to do hence why she has been to frightened to drive the car for 10 year's.
Hope this helps
Post by Not_Anumber » Wed Sep 04, 2019 11:50 am
Its great that you are using V6 parts for this and doing it the traditional way.
I got talking to someone at the Dunton show the other day who had installed electric power steering which mounts on the column and top of the pedal box but uses the original non PAS rack. It was a neat job but struck me as quite expensive.
Ive been looking into it as i was looking into ways of adding power steering on my non Capri project but suspect that only electric steering will do for that as there weren't any variants of that car ever made with power steering.
