Whining Noise
Cosmicbike
Whining Noise
Post by Cosmicbike » Mon Aug 19, 2019 11:09 am
Debz (as she's now known) was pressed into action this morning for the dump run, the old shower screen won't fit in Festa and I'm not allowed to take the van to the dump.
Anyway, today was her longest run at 15 miles round trip. I noted a 'whining' noise most of the time we were moving but couldn't pinpoint the source over the various rattles.
I don't believe it's engine related, when stationary no noise or through the rev range.
Dropping out of gear and coasting with the clutch either in or out the noise continues until a near stop, which suggests drivetrain? I gave the front hubs a good yank around when I did the brake lines and they felt OK.
I'll pop her rear end up later and check the rears, but it they are iffy then it's half shaft bearings I guess, and from previous experience when they fail the back of the car feels wobbly which I haven't noticed.
I haven't check the gearbox oil level so that may be worth a looksy.
Any other pointers please?
Re: Whining Noise
Post by Paul G » Mon Aug 19, 2019 11:34 am
Propshaft centre bearing.
Cosmicbike
Re: Whining Noise
Post by Cosmicbike » Mon Aug 19, 2019 12:20 pm
Thanks, I'll add it to the list
Cosmicbike
Re: Whining Noise
Post by Cosmicbike » Mon Aug 19, 2019 2:58 pm
Well that's learnt me nowt.
Both rear wheels are solid, tiny bit of backlash across the diff but I suspect that's normal.
Propshaft bearing seems solid, I can't get any play in it side to side. As above, small amount of backlash into the diff.
Gearbox seeps oil out of fill hole with car level (that's great fun doing that isn't it, I need a smaller head :lol: )
Just have to turn the radio up I guess.
Re: Whining Noise
Post by andyd » Mon Aug 19, 2019 3:22 pm
Have you got a woman in the boot :lol: :wave:
Re: Whining Noise
Post by Mc Tool » Mon Aug 19, 2019 6:05 pm
Yeah , I was going to say are you sure it's the car ( we have jokes about that sort of thing here ) :xd:
Most likely either the diff pinion bearings or the tail shaft / layshaft bearings. A whine usually implies a bit of speed involved and wheels turn slow so their bearings usually rumble.
I bought a 2nd hand t9 supposed to be low miles but it sounded like a concrete mixer, but by then I had sold the 4 speed so I was stuck with it ......done another 40,000 miles and it ain't got no worse :roll: ,so don't panic :D
Cosmicbike
Re: Whining Noise
Post by Cosmicbike » Mon Aug 19, 2019 7:43 pm
Whilst no passenger seat was fitted, I'm reasonably confident I left SWMBO at home ;)
I'll not worry too much, she only has to do a few hundred miles maybe and get to Brooklands before coming off the road, maybe I'll find something then.
Re: Whining Noise
Post by stevemarl » Tue Aug 20, 2019 12:31 pm
THere won`t necessarily be play as such, bearing races can make horrible scraping, humming noises without any perceptible play. Only way is to take it out and roll it in your hand for roughness. This is by far the easiest option, it`s an easy job*. As Mr McTool says though, it could also be the pinion bearing or the mainshft in the gearbox as they all turn at the same speed.
* EDIT: I`m assuming you mean the prop centre bearing
Cosmicbike
Re: Whining Noise
Post by Cosmicbike » Tue Aug 20, 2019 6:35 pm
Noted. I'm used to using a listening stick for bearing rumble, but didn't fancy laying under the car with the wheels spinning..... In keeping with the 'nothing major until after Brooklands' theme, it'll have to wait.
